Question about Refrigerators
Can't change the augerin the ice maker I have the new auger but don't know how to change it. PLEASE HELP
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Perhaps you should try service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
Ice maker does not dispense ice through the door
Hello. I had the same problem. I replaced the auger motor(around$95) 3 times and would only last about a little longer than a year. I bought the 4th one but this time, I wanted to diagnose the issue. So it turns out that the auger motor goes installed with the impeller upwards. What was happening was that if a piece of ice would stay in the dispenser chamber and melt, the water would go into the auger motor eventually causing the auger casing to get full of water and slow it down or short it out. I took the casing apart and noticed that there was a small space between the motor and the casing. I drilled 2 nice sized holes in the dimple of the new motor very gently as to not drill into the impeller motor and installed the auger. To this day, 3 years later, no more having to buy new auger motors. Hope this helps!
Mar 10, 2015 | Refrigerators
How to change auger in ice maker
Good Morning Friend,
I understand you are trying to change the auger in the ice maker of your Frigidaire refrigerator, model# FRS3R5EMB. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to change the auger with ease. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
I have a clear view ice maker and it fills fine and makes ice but it don't empty
Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
+auger in ice maker broken Can replace auger only? part?
Hello, Thank You for using FixYa. I will be helping you today.I checked every where and the ice stripper is no longer available for that ice-maker. You would have to replace the whole ice-maker.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
Replaced water valve but still will not supply water to the ice maker
Because your model has the mechanical type ice maker it is likely the ice makers thermostat is the most likely problem. Test ice maker by filling with tap water. Once the water freezes te thermostat tells the ice maker first to warm the bottom just long enough to cause the cubes to loosen in their slots and next th rake begins to cycle the cubes up and out of the ice maker and into the storage and auger pan. If the water just freezes and the ice maker does not cycle the you know the water control valve is new. The thermostat is what tells the cycle to begin. depending on the age of the ice maker just changing the defrost thermostat would be the best choice. I will display photos and links in a few moments, Sea Breeze
Mar 04, 2010 | Whirlpool GD2SHGX Refrigerator
Broken auger on ice maker needs to be replaced. Can't get apart.
You will have to remove the E ring that attaches to the end of the auger before you can pry the pats apart.
Please rate solution
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Motor went out on kenmore ice dispenser. how do I change it.
need new auger motor remove ice bucket and ice maker remove back panel remove auger motor and replace put it all back in reverse.
Aug 17, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
The auger arm doesn't turn. The ice maker still makes ice, it just can't dispense.
Take the ice container with auger inside it and defrost it. Withe the door open to the freezer push the switch that turns light on in freezer to turn it off. Have someone push the ice dispenser switch while you hold the light button in. Tell me if there is any movement in the auger motor in rear and let me know what you find. Thanks, Sea Breeze
Jun 01, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Drive Mechanism Doesn't Turn
pull the ice tray out and have someone push the ice botton,look to see if the auger arm in back is moving and the ice tray auger is moving ,let me know what you find-mike
Oct 09, 2008 | GE Monogram ZISS420DRSS Stainless Steel
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
