Question about Hotpoint VBSR3100D Top Load Washer
Washer overflows The water over flows on the large loads only.Everything else works fine on the other two levels.
    Genius:
  • 1,028 Answers
Remove front panel by pressing clips along front edge down with putty knife on left side of tub is small hose ckd at very end of hose and where it goes onto tub for a blockage usually indicated by dark spots ..lint may have backed into hose and caused obstruction..if cks ok remove screws along top edge of console ..console will roll forward other end of hose goes to water level switch on left if hose is not plugged or pinched replace water level control
Posted on Aug 29, 2008
Maytag washer overflows
Remove and clean the water level tube that connects to the tub at one end and to the water level switch at the other end. Probably it is full of gunk.
May 28, 2017 | Maytag Washing Machines
Do water level is not working. It will over flow
change your pessure switch. Thats the switch that says
medium low or high loads
Jun 06, 2010 | Kenmore 22422 Top Load Washer
Washing machine is overflowing, even set at low water level.
sounds like your pressure tube is not functioning correctly.
Aug 22, 2009 | Kenmore 23822 Top Load Washer
Have a GE washer model WWSR3090TAWW, S/N DT106239G. The washer overflowed, and repaced the water level switch. It tested okay. Later when a load was done, it did the same thing. I have checked...
Here's the acid test: If the water is overflowing, turn off power (timer off, unplug machine, or switch off breaker) and if water stops flowing, you have a bad water level switch or obstructed water level tube leading to the level switch. If the water continues to flow in when power is off, and the only way to stop it is to shut off the water supply valves, then replace the water inlet valve of the washer, which for your machine is part number WH13X10024 and generally goes for about $50.
Aug 21, 2009 | Washing Machines
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Wrong water level
sounds like a water level issue, it located behind the console2.gif . before replacing switch check the clear plastic tubing going to it for any cracks or holes, and make sure its attached to the rear of tub properly. air pressure goes up that tube tripping off switch so check it first.
Mar 14, 2008 | Kenmore 23022 Top Load Washer
Overflowed on Large load size
i think the water level sensor tube got filled when you had it on it's side, then after the first spin and drain cycle, the tube was again cleared out and ready for real action.
Oct 29, 2007 | GE WJSR1070A Top Load Washer
Hotpoint VBSR3100D Top Load Washer Logo
44 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
