Question about GE 24 in. GSD4030Z Built-in Dishwasher
CAN NOT REMOVE THE END CAPS FROM TOP RACK TO REPLACE THE ROLLERS
The end caps on the upper rack of my GE dishwasher do not pull off, they "rotate" off by turning the top of the cap toward the center of the dishwasher. In order to make this rotation, you need to slip a small screwdriver in the track to the inside of the nipple at the top of the back of the end cap and force the nipple toward the middle of the dishwasher.
DBK
Posted on Nov 07, 2008
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Use a small channel lock wrench and wiggle it gently while pulling it out not to crush anything!
If you can't free it , better to call service than cost more money breaking it!
Perhaps you should try service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
How do I get the upper rack arm back on the rollers?
The back endcap on the slider has snaplocks that has to be squeezed then pull off. This should allow you to pull the slider out and then guild it back over the rollers and into its proper place. Just had to do this, and it's hard to get to with the door down, but can be done.
Jan 13, 2015 | Dishwashers
Remove upper rack
When you pull the upper rack forward, the two metal glides on each side move forward. On the end of each glide is a white plastic end cap. If you look through the rack to the inside of each glide, you can see that the upper part of the end cap has a upper tab. I put my thumb on the end cap then press the upper tab forward with my index finger. Then press upward with your thumb and the end cap should slide totally upward and then out of the glide. Once both end caps are removed, the upper rack slides fully out of the washer.
Jan 25, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
Install upper rollers to Westinghouse dishwasher
Without much more to go on, I am assuming you are trying to install the "rack" onto the guide with the wheels. Usually there there are "end caps" on the guides that need to be removed first. Sometimes there is a small "tip" sticking out the top or side that has to be pushed in to release the end. Sometimes they are just a snug fit and will pull out.
I have always had good luck in going to a manufacturer's web site and or a site that sells replacement parts. There is usually a schematic of the area that you are working on and it will give you a better idea of where the part is that you need to remove.
Also, I have gone to the parts department of an appliance store and showed the parts guy what I had and they usually just tell me for free what I needed.
Good luck.
Apr 06, 2013 | Dishwashers
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
How can I disassemble the Eureka Altima Brush Roll (#60844-7) for cleaning? Thank you, Jerry in Irving, TX
You can remove the two screws in the top cover above the roller. Then lift off the top cover exposing the roller. You can then pull the roller out, and clean out the cradles that hold the end caps. The square end caps can also be pulled off the bearings at the ends of the rollers. I had a lot of stuff wrapped around mine creating a lot of drag, but the bearings were just fine once everything got cleaned out. Just remember which end cap is which, cause they're different for each end.
Oct 05, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
Water not getting to upper wash arm / glasses on top rack are dirty after the cycle - I do not know how to take out top slide basket to check water flow in tube at rear of machine-
remove the roller rack plastic end caps this will let you remove the upper rack,then you can replace the whole wash conduit from the bottom sump all the way to the top,also if theres a middle(center arm) this has a horn on it that is to seal when the rack and door are in and closed,but after while the water wears out the plastic o-ring and they leak and you lose water pressure to the top wash arm
Apr 01, 2010 | Dishwashers
How do you install the end cap #wd12x344
Use a pair of needle nose pliers. Gently bend the end of the rack opening out just a little. The cap will snap in place. Gently bend the rack tubing back in.
Nov 22, 2009 | GE 24 in. Profile PDW7800 Built-in...
I can't put back the top dishwasher rack. The railing does not seem to hold it, even though there is no damage in the railing. The top rack could not be held by the rollers
There should be plastic stops at either end of the rail that prevent the rollers of the rack from coming out of either end.
Sep 22, 2009 | Maytag Dishwashers
How do you remove the caps from the upper rack glides? I'm replacing the rollers that attach to the upper rack because one is broke.
Caps on the front ends of the glides can be pulled out. Sometimes they are hinged at the top and have a tab at the bottom to pull out. With the caps out or open you can roll the upper rack out of the glides.
Aug 12, 2009 | Dishwashers
Top rack rail contently comming off the rollers. The rollers are wobbly, tried to tighten but will not go any tighter. are there better rollers available? PLD2850RDC2
Typically the roller wheels and the post tabs that hold them onto the sliding rack/guides will wear over time and depending on how heavily your family loads the racks, the sooner you'll need to replace them.
You can order new ones and do the job yourself which is the best solution for the situation you're describing. The only other thing to check is for the rack section that is attached to the inside dishwasher walls to make sure those screws are snug (don't overtighten and strip them out!) other than that, you still will need to replace the rollers on the extendable portion of the rack supports, etc. Hope that helps.
Jul 13, 2009 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwashers Logo
178 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
