Question about Nokia N95 Cellular Phone
Losses its battery charge within 3-4 hours
The problem of my phone is that it's losses its battery charge within 3-4 hours. So, i went to several technician to do something about it.They say, probably it is due to the battery, so I change it with anew one but still the problem is still the same. Then, they say probably it is infected with a virus or something is wrong with the program so they reprogram it and scan all the file. But still the problem was not resolve.I also observed that the battery is hot. Help me, what can I do? Thanks
  • 3 Answers
Is the telephone reception ok? If there is a reception fault this may cause the phone to continuously look for a signal and wear down the battery.
Posted on Aug 29, 2008
Lg thrill wont charge
Date: May 16, 2014
I have an LG Thrill 4G. My phone just went thru an issue where it wouldn't charge past 4%. Sometimes, it wouldn't go past 2%, so I had to leave it on the charger ALL the time - or risk it dying, completely.
For days, the only services shown on my battery usage were:
Cell Standby: 33%
Bluetooth: 33%
Phone Idle: 32%
Display: 2%
I replaced the battery with a brand new one - NOTHING changed. Battery still sat around 2-4% for the entire day, while on the charger. So, I started uninstalling apps like crazy - just to see what would happen.
NOTHING. Same thing.
So, I decided to at least install the Facebook app back...and the upgraded version had to be installed - so I did it.
VOILA!!! My phone instantly started charging ...8%...14%...24%...52%...80%...91%...all over a period of about an hour. Just a constant charge going up a few percentage points every few minutes...
...and all of a sudden, started going back down pretty rapidly when it hit 92%. Within maybe 3mins, the charge went from 92% to 78% - and I wasn't using the phone. I was just watching the meter drop 2 percentage points over a period of a few seconds, each time. I decided to quickly turn the phone off at 78% but left it on the charger.
After roughly 5mins, I turned the phone back on, just to see what the charge would be sitting at. WOULDN'T YA KNOW - 3%.
How can battery life go from 78% to 3% - while it's OFF - within a 5min span??? Therefore, my question is: was it really charged to 78% when I turned the phone off? Or was the battery meter being "tricked" by some app that might be installed?
The first battery it did this to was the 1500mah. Used that battery for like 3 days of this before I replaced it. The battery the scenario above JUST happened to is my new 3500mah battery, and it's been giving this 3500mah battery the 3% capacity for a whole day and a half now...
Mar 29, 2013 | LG Thrill 4G
Fully charged battery not holding for a full day
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 05, 2011 | Samsung Cell Phones
Lglp-ahmm sbpp0027708 sbl dc100725 battery in lgcx9200 cell only holds charge for about 10mins is there any way to force charge or reset the battery?
Under normal useage, the battery should hold a charge for at least an hour. Usually a lot longer depending on what your doing. However, the internet will kill a battery within mins! So keep your phone plugged in while your on the internet and even while doing other things until its fully charged. Shut your phone off when you go to bed and plug in the charger. Then unplug it when u wake up. If your battery still gives u severe problems, the battery cells may be totally dead or defective, in which case you will have to buy a new battery.
Jul 20, 2011 | LG VX9200 enV 3 LGLP-AHMM BATTERY
Battery power is very weak
    1. Try this first  power off your cell phone and charge it for 6 hours
    2. remove the charger and power on your cell phone start using it
    3. please note that don't use your phone while charging unplug it if you need to use
    4. only recharge it when it shows battery is low
    5.  please buy and use original battery and  charge
    6. I am sure that you can see the difference
    Jun 20, 2010 | Nokia 6500 Slide Cellular Phone
    My iphoneran out of battery and wont charge (i think)
    try leaving it on charge for a few hours, otherwise that ipod radio could have damaged it
    Nov 02, 2009 | Apple iPhone Smartphone
    T20 batteries wont stay charged
    It might be that you are using older batteries. However, you should try dimming your backlight to the lowest possible setting and performing any other power-saving actions such as limiting the processor's power (if available on your laptop.) Hope this helps.
    May 09, 2009 | IBM ThinkPad T20 2647 Notebook
    My phone nokia n95 losses its battery charge every 3-4 hours
    Its time to replace the battery. Also check that the charger is working properly, and the contacts on both the phone and the charger are not oxidised. If they are, try scraping the contacts gently with a sharp object like a jeweller's screwdriver , etc..
    Oct 25, 2008 | Nokia N95 Cellular Phone
    hi
    you changes the batteries and reprogaraming the mobile in this whole mean while did you use the same charger if yes so you porably charge your mobile with the another one because you said the battery became hot is only becase of the voltage may be the charger capcitor lose their power to store the voltage so you just check the another charger.
    thanks
    your friend from fixya!
    Charge
    hi your battery has created a memory because you didn't follow simple battery guidelines:
    For a new phone with a new battery;
    1)Use the phone the first time until the battery dies,
    2)Do a full charge - 6-8hours for the first time
    3)Use the phone until it dies the second time
    4)recharge the battery for 3-5 hours
    then your battery should be good, but now your battery needs to be changed, as it already has memory and can only be restored if completely discharged by a battery conditioner
    Jan 30, 2008 | Motorola Mobility RAZR V3
    Nokia N95 Cellular Phone Logo
    56 people viewed this question
    Top Nokia Cell Phones Experts
    IT Solution
    IT Solution
