Question about Sony Cyber-Shot DSC-F505 Digital Camera
Batteries for Sony DSC-F55 or DSC-F505?
Hi I was just wondering if anyone knows if the infolithium battery type NP-F550 or NP-F330 will work with either the DSC-F55 or the DSC-F505 cameras?
    Master:
  • 551 Answers
No, those are 'M' series batterys and the F55 and F505 take 'S' series batterys.
Posted on Sep 08, 2005
2 Suggested Answers
vega
  • 551 Answers
SOURCE: Batteries for Sony DSC-F55 or DSC-F505?
Sony Cybershot Dsc-505
Are you sure it is your charger and not the battery? (Batteries)
You could buy a new Sony charger, but there are lots of universal camera battery chargers, that won't cost as much and you can use it for every battery from every camera. Pick the right one and you have a charger for years to come, whatever your new camera will be and how big or small the batteries are.
Jan 05, 2014 | Sony Cybershot DSC-F505, Cybershot...
Tip
Sony np-f330 battery...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 19, 2010 | Computers & Internet
Battries run out of power,while camera is turned of.
The batteries on the DSC-V1 will be around five years old now so that's to be expected. You need to replace faulty batteries with genuine and new Sony InfoLithium NP-FC11. Many cheaper "compatibles" exist, but at best they don't last as long and will not give any battery charge indication (they lack the InfoLithium chip) and at worst they can damage the camera.
Unfortunately, genuine batteries are so expensive that you might decide it's time to upgrade, but as the DSC-V1 is such an excellent camera it's not a straightforward decision. Newer = more megapixels, but also = noisier images. 5MP is easily more than enough for prints up to A4 size even allowing for a bit of image cropping.
Oct 24, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Charge
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
S75: which battery???
Please note that the webpage has been updated to reflect the proper battery to be used for the Sony Cyber-shot DSC-S75. Links work properly, now. http://www.sonystyle.com/digitalimaging/cybershot.htm
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
DSC-F55 serial connection a disadvantage?
It would take atleast 4 times longer compared to USB. (maybe looking at upwards of 10X slower) I've got the F55 and suggest buying the floppy disk adapter, its only $60 or so and will speed up the xfer considerably. I would say 4times faster.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sep 08, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Adding zoom lens to F55?
Zoom can be added to the F55 by instead purchasing the F505..
Sony Cyber-Shot DSC-F505 Digital Camera Logo
140 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
