Question about Epson Stylus Photo R220 InkJet Printer
Epson Photo R220
It is not responding when I try to print. I tried turning it off, shutting down everything, unplugging and plugging all cords back in. It will print test sheets but no response when I try to print anything. Please help!
    Problem Solver:
  • 6 Answers
Epson printer R 230 flash how
Posted on Sep 03, 2008
Was printing labels and the feeder pulled the page through crooked so it jammed. I pulled the paper out, it ripped, I opened the printer and got the remaining peices out and shut off the printer. When I...
ALthough you didnt give the model of the printer this has helped reset it on other epson printers.
unplug the printer from both USB and Power.
Hold down power button and then plug in the printer while the power is held down.
if this doesn't do it try holding down the paper button and the power, while plugging in. since this can be tricky, plug it into a power strip so you can power off and on easily. This is a help at the bottom for a R220 that mentions somthing similar.
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/parts_1.htm
Mar 11, 2011 | Epson Office Equipment & Supplies
I left my Epson Stylus Photo R220 InkJet Printer conected to power for some days without using it. when I tried to start it the power refused to come on.
try replacing the power adapter n cord..
if u r a professional check the fuse, transformer, diodes n transistor in the switching section of the adaptor as well as the printer..
if u r not, better to seek a professional supervision or contact ur system admin/vendor....
Oct 29, 2009 | Epson Stylus Photo R220 InkJet Printer
Pictures wont print correctly with vista
Are you using the correct drivers for Vista or just the disc you used before?
Download the latest Vista drivers from here (32bit)
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R220/Drivers-Support?_DARGS=/jsps/support/modules/mainContent.jsp#
If you have Vista 64 bit just change the system in the drop down menu.
Aug 15, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson r220 prints black lines through photos ect anything I print
The problem caused by waste ink at bottom plate arround head sprayer. Clean it. Turn off printer. Move head to center. Put wet tissue (with warm/hot water) upper head cleaning pad. Move head to right (parking position). wait for 10 minutes. Repeat it for 2-3 times. Check nozzle.
May 30, 2009 | Epson Stylus Photo R220 InkJet Printer
My printer will not turn on
Here are some things to try:
1. Different plug (outlet) just to make sure it isn't the plug causing an issue.
2. Unplug the power cable from the back of the printer itself if possible and plug it back in while holding down the power button.
3. Unplug the printer from the computer all together and see if it powers up.
4. If it's a separate power cord try to find one similar in nature to plug in and try out as it may be the cord.
Apr 29, 2009 | Epson Stylus C66 Photo InkJet Printer
My epson C62 died while I was printing a document. The red light is on, green light off. the ink containers do not move entirely to the right where they belong. Does not respond to any signal.
This indicates a so-called "fatal" error. Because your print-head cannot fully move into its parking position on the right, it seems likely that the parking mechanism has come adrift. Turn the printer on, and as soonas the print head tries to move, pull the power cord out of the printer. You should now be able to move the print head (gently) out of the way and see into the parking area. If there is a plastic rod sticking up, ull it gently towards you and it should snap down out of the way. The printer should now work. If the problem re-occurs, it means the mechanism is clogged up with dried ink. Try repeating the above process a few times to see if it clears it.
If you see that the whole parking mechaism has come adrift, this almost certainly means the front spring has come off. This will require the printer to be dismantled I'm afraid, so will cleaning the print mechanism. Service Manuals are available to help with this.
Report back on what you find
Jan 13, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson r285
HI
Try reinstalling the inks, make sure you here a click when you press it down. If all fails you are having a hardware issue. call epson for replacement.
Hope this help
Dec 31, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r220
Open the printer Properties, Under quality there should be a box
that you can check (print in greyscale) or (print in black & white).
You have to remembe to uncheck to print in color.
Feb 04, 2008 | Epson Stylus R220 Photo Printer Color...
Printer won't stay on
Your printer need reseting
Ask to epson manufacturer if they have R220 reseting CD.
Dec 20, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
