SHARP GA293WJSA How do I view a picture. My friend gave me the tv and I plugged it in but only get a blue screen. What do I need to do?
  • mary3958 Aug 29, 2008
    What do I connect to it? I hit the input button but nothing happens
  • 71 Answers
You are not receiving a signal. The signal source, usually labeled "INPUT", may be selected that has nothing connected to it.
The above assumes the TV is working.
Posted on Aug 29, 2008
  • Ignatz Saturation Aug 29, 2008
    Hi.
    Did you connect your antennae cable to the TV's antennae cable?
    Did you attach the plugs of your DVD or VCR output into the TV's input jacks?
Change TV resolutions to view slide shows
Nope. The picture resolution has to be 1080 to fill the screen completely. Using stretch and zoom will distort the low rez pictures. No option to change resolution on the TV itself.
Jan 23, 2014 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Blue pixelation spots all over main viewing screen.
Your dlp chip needs replacing. It's a job to do but you can do it.
Jul 23, 2017 | Sony Video Cameras
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Blue screen
It sounds like the cooling fluid in your picture tube(s) has become dicolored - this can be seen if you dismantel the unit and view the picture tubes directly - they will appear foggy - replacing the fluid can be a time consumming and expencive task.
Sep 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Toshiba 32'" tv wont give sharp picture
no rocket science here - my son fiddled with the cable cord attachment, until presto, the screen became sharp. Then we moved away as fast as possible, lest we shifted it and it put us back at square one.!!
Jan 26, 2009 | Toshiba 36A50 36" TV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Setup Menu will not display on TV screen
Ok, on the back of the unit, there is a single yellow composite output. There may also be a Red, green,blue.Component. Take 1 RCA cable and plug it into that yellow output, and route it into your TV input, also a yellow composite. Make sure that whatever input you put that into on the tv, that you change the TV input to that to view your player. when and if you get a picture, you should be able to get to the menu through the GOVID remote.
Later once that Path is working, you can upgrade it to the Red,. green, blue, if your TV has the inputs. You did not give a model for the TV or I could tell you what it has.
If you need any more clarification, please reply.
Best Regards,
Charles
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
Need help setting up My Sharp Aquos LC-32D44U, also volume issue
GA293wJSA my friend gaveme this sharp tv. Nothing happens after I plugged it in I just get a blue screen what do I need to do to view a picture?
Jun 12, 2008 | Televison & Video
Sharp v29j200s always blue on the screen
Sharps are known for bad tuners and cold solder joints.If you tap on tuner and picture comes back there is cold joints in tuner, If not most likley bad tuner. if the audio is there with blue screen it is the tuner definitly.good luck
thanks DOCTOR VIDEO
Mar 25, 2008 | Orion1934 19" TV
Playstation 2 not working
if you getting a blue screen and NO browser, the system is probaly damaged, either try another AV cord to plug into tv, if that doesnt work then its something internal
Jan 22, 2008 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
