Question about HP iPAQ H2210 Pocket PC
Wi-Fi SD card
Does anyone know why my Wi-Fi SD card does not get read by my HP IPAQ 2210 pda?
  • 31 Answers
Hey, id be happy to help :), the reason why your SD wifi card is not getting read by your pocket pc is because. The wifi card you have is probably have was made for a regular computer and is not compatible with your pocket pc. Id recommend for you to find a SD wifi card that is compatible with your pocket pc. And return the one you have now, thanks and I hope this helps!
Posted on Oct 11, 2008
How do I setup my HP iPaq 2210 to access the internet with a WLAN-11b card? What are the steps?
First of all, you should install the driver for your wlan-11b card to your PDA. (There should be a CD given with the wifi card, or you can download in online through the card's brand's website, ex. .cab file for a Spectec SDW821 Wi-Fi Card) At this step, you should be carefull with the version of windows mobile on your device and the driver's version for windows mobile. After that, you should plug your wifi card to your PDA's SD slot, and your PDA will recognize it. So you can go to your settings, and there you can search for a wireless network.
Apr 15, 2009 | Compaq iPAQ H3630 Pocket PC
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
HP5550 Storage Card
The HP h5550 is a bit old PDA , and it cant recognize it.As i know , there is actually no way to connect it.Sorry.
May 09, 2008 | HP iPAQ H5550 Pocket PC
SD Card not reading
I had this problem once and found after tedious looking that one of the pins was bent inside my HP 3715 PDA. I used a very small needle nose and a safety pin and pushed it back in location. Has been working ever since.
Mar 22, 2008 | HP iPAQ HX2490 Pocket PC
Installing a SD wi-fi
First remove the SD Card, then remove the drivers for the SD card. do a soft reset. install the driver for the card. go to settings, system, then remove software and check tat the software shows up. Oh by the wy make sure you have the HP SDIO fix install first. ok make sure that bluethoot is off. Install the SD Card. now go to settings, then connections tap on connections. tap the Advanced tab, tap the Network Card. you should see the SD Card listed. tap the Card. the next screen ask if you want to set the IP address or have the server assign the IP. I leave it at the default and let the server assign the IP.
Tap ok 3 time that should close everything. and you should be set. if you have a wi-fi setup you need to tap on start then programs, then tap on "WLAN" this program is what you use to check your signal strenght and check if you are getting a signal from your wi-fi. Once the signal strenght is strong enough you will see that an IP address will be asigned and you will be asked if you want to connect.
I hope this Helps
Oct 17, 2007 | HP iPAQ H2210 Pocket PC
Wi fi connection problem
It could be that your connection is ok but the cached files and cookies are corrupt. Clean out the cookies and temp internet files in the temp folder or whatever your pda uses to clean itself of old files.
Jan 27, 2007 | HP iPAQ HX4700 Pocket PC
Cannot see any SD card in expansion slot
The first thing to try is a soft reset while the card is inserted.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
HP iPAQ H2210 Pocket PC Logo
216 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
