Question about Car Audio & Video
Hello i would like to add a din head unit a few 6/9s and maybe a sub if poss into my saab 9-3 vector sport 56 plate is it possible with my existing 7 factory fitted speakers so that when i come to sell my car i can just remove the equiptment i have added and replace it with the orignal stereo. Or is it poss to do the above without replacing the head unit??
    Novelist:
  • 100 Answers
My suggestion is to go to your local audio shop and pickup a dash kit and wiring harness to hook up the din head unit. I actually wouldn't recommend putting in aftermarket speakers unless you don't plan on reselling or they are blown. You could hook a sub up by running your power wire to your amp like usual, hook your amp turn-on wire to an accessory wire and buy a "line level converter" you will tap into factory speaker wires with this and it will convert it to RCAs. You will only need to do this if you are using the factory head unit. Also, unless the aftermarket unit has features that you want that the factory one doesn't, I wouldn't bother with that either. Good luck. Let me know if you need any more help.
-Andrew Hawkins
Posted on Aug 29, 2008
Start power cut
try the idle control valve it could be starting to fail.
Jan 20, 2014 | Saab Cars & Trucks
93 Vector Sport. Turbo keeps cutting out
very common issue with post 2001 turbos. the fault is usualy down to the air flow meter (mounted on the airbox or induction pipe). you will find its at its worst when warm. do not fall for a garage telling you the turbo has failed.
Jan 26, 2010 | 2004 Saab 9-3
I have a Saab 93 TID (2005 Vector) KEYFOB PROBLEM!
I suspect you have a problem in the security system receiver module, which in most cars must be programmed by the dealer.
May 12, 2017 | 2004 Saab 9-3
Dash board, head unit/ subwoofers 2005 saab 93
www.crutchfield.com has a "what fits" section, it will allow you to pick a new head unit that will fit the stock size of your SUV. As for as Amps, a Bass tube or Subs, they will help you too. They sell you have any thing you will need. Remember, this tip, grounding cables need to be drilled or bolted to a non-painted surface to the chassis.
Aug 20, 2009 | 2006 Saab 9-7X
My Saab 9-3 1.9tid 150bhp Vector Sport on a 2005 plate
check EGR,MAF,injectors,high pressure sensor(fuel)
Jun 17, 2009 | 1999 Saab 9-5
Front Springs
I spoke with the Saab dealer whom sold me the springs last March, he told me there is an ongoing problem with many owners having to change springs, I have bought 2 x new springs and had them fitted total costs incl repair of damaged tyre £450, I will not be as originally planning purchasing another Saab, after sales are poor and excuses unacceptable when requested they honour warranty.
Feb 11, 2009 | 2004 Saab 9-3
Broken lense on my front fog light
you should be able to take the lower splash sheild off and get under the vehicle then there usually are 3 bolts holding it in unloosen pull out fog lght put another in
Jan 26, 2009 | 2008 Saab 9-3
How do i install a subwoofer and amplifier to an exhisting car audio system
The basic would be to wire the sub amp to your batteries with the trigger/remote wire powered by your car stereo/head unit. When your head unit is turned on it will in turn power up the sub amp. Of course the sub woofer need to be wired to the amp. For the signal/audio wiring, normally, the head unit has a stereo RCA female connectors at the rear intended to be connected to external amps through a pair of shielded/audio cable terminated both ends with RCA males. Some units have a special RCA specifically for subs. Most eternal amps also uses RCA for their inputs.
If the existing car audio system has already an external amp and your plan is to add on to this, the audio/signal from the head unit could be split to provide both for the existing and the new sub amp.
If the existing car audio does not have an external amp and their are no RCA connectors at the rear of the head unit, it is still possible to connect an external/add on amp by using an adapter that connects to the speaker wires of the head unit and converting it out to line level (through RCAs) appropriate for the input of the amp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information. it would also be nice if you can post brand/model of your head unit and intended sub amp.
Good luck and kind regards.
Jan 23, 2008 | Audio Players & Recorders
Car Audio & Video Logo
171 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
