Question about LG 50PC1DR 50 in. Plasma HDTV
Tv guide on screen
Ever since a recent power failure, my tv guide on screen will not work.
  • 71 Answers
Have you tried unplugging the TV, wait a minute the replug it in? TVs have built in computers and often they may latch up, like a bug and need to be 'rebooted'.
Posted on Aug 28, 2008
Can you help me please? I have detailed below the specifics surrounding the TVs failure.
Check for a short-circuit, which is probably tripping the circuit. It's most likely intermittent failure in the power supply circuitry of the TV. A good electronics technician should probably help you out.
Feb 14, 2017 | Samsung Televison & Video
The tv suddenly goes black and the power light blinks red
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
The fan has stopped working
Check and replace either the damaged fan or its speed regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Toshiba 55TL515U 3D LCD TV
Sony tv guide screen not working
That feature may require a box to be inline now-recently a lot of the settings for this feature have changed.
May 13, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
Blank White screen
A blank white screen is one of the symptoms of a failure in the power supply board. The power supply board is not putting out all of the correct voltages to power up the TV. These types of problems are caused by parts called capacitors. They filter the output power and when they die the power supply can not operate correctly. This is easy to repair if you can do a little soldering. Here is a link to a repair guide for this model.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-fla-01911c-with-a-bad-power-supply/
I hope this helps get your TV back running,
BuddyMc
Apr 09, 2012 | Polaroid TLA-01911C TV
My on screen TV guide no longer works, and my TV keeps losing time (between 10 and 20 minutes). I'm not sure how to fix this. Is this a hardware issue or a settings issue? Has someone else had prior...
Do you have cable TV? Many Cable TV companies have recently (over the last year or two) quit sending TV Guide data. You can get it through an external antenna connected to the TV's antenna input if you are within range of an ABC or NBC and a PBS affiliate for the clock auto set.
But if you still have TV Guide service, some of these have failed circuit boards for the TV Guide, ( usually shows a complete black screen when you turn it on or hit guide button.
Apr 13, 2010 | LG 50PX4DR 50 in. Plasma TV
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
Plasma TV - intermittent blinking
Power supply failure. Either a capacitor went bad, or there is a loose solder joint near the big transformer on the power board. I would guess loose solder connection.
Nov 14, 2008 | Televison & Video
Sony tv video
High voltage power supply failure usually caused by bad solder connections in the horizontal drive circuitry-commonly aggrivated my a recent move of the tv.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LG 50PC1DR 50 in. Plasma HDTV Logo
235 people viewed this question
Computer Repairing
Computer Repairing
