Question about Canon PIXMA iP8500 InkJet Photo Printer
Error Number : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
Hi- Could you help me get my printer working?  THe printer is on and I am pretty positive that it is added as a printer on my computer.  I am working on an imac. Thanks Lisa
  • 2 more comments
  • palmergs Dec 13, 2008
    Same problem. Mac Pro laptop wireless connection to AirPort. Printer is network connected to AirPort.
    Interestingly, I can print the test page (using the canon utilities) through the wireless connection AND I can scan into PhotoShop using the wireless connection. But, as of yet I cannot print from an application .
  • Jayheypete Jan 04, 2009
    I have the exact same message when I try to print from an application. I am running a Canon MP180 through a USB port into my MacBook. I can scan using MP Navigator and all diagnostic tests of the printer come out clean.
  • Anonymous Mar 01, 2009
    Sweet I didn't type anything but I had the same problem.. . . and your solution worked thx!
  • Jo Smith
    Jo Smith May 06, 2014
    i too have this problem. I cant however even print a test page. but the printer is installed on the mac as I can see it, but there is someow a glitch? in getting the message to where it needs to be..
I had this problem with a Canon IP5200R connecting to a Mac Book Pro running Leopard. I had setup the printer as per instructions using the setup utility, could print a test page using the utils but could not print from an app.
My solution was to delete the printer (System Prefs > Print & Fax) listed in the system preferences and then re-add by clicking the '+' in the pref panel, then selecting 'More Printers' from the popup window. If you have the printer connected to the network correctly it should show up and you can simply re-add it. My printing now works correctly.
Posted on Jan 25, 2009
Thank you DrinkingBudy! That cleared things up!
Posted on Feb 15, 2009
Error c410, is it a serious problem ie costly to fix or how easy itto fix it?
That is a general printer error. Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well. Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on. Make sure that the hardware is properly plugged in.
Jul 04, 2012 | Office Equipment & Supplies
Printer power on/off button does not respond and northing works
1) Connect the printer directly to the walloutlet..
2) Try with different wall outlet...
3) Check if the button is stuck inside or not..
4) Remove the power chord from he back of the printer and then press and hold down the power button for 30 sec... release the button and then plug in the power chord...
Check if the power button responds or not...
5) Check if there is any light on the adaptor or not or if the printer has any light or not...
if there is no LED light on the adaptor it is a problem with the power adaptor ..
If there is light on the adaptor as well as printer and power button does not respond it is an issue with the printer..
You must replace the printer...
Jan 24, 2011 | HP Photosmart C5380 All-In-One Laser...
I have the same Error Number 300 with my Canon MX850 - it is connected by ethernet cable to my wireless router. I can scan documents OK, but when I go to print it says that the printer does not...
Hi Daniel, I just had a quick look and other people here have posted problems regarding error code 300 on the MX850. Take a look here when you get a minute to see if any of the solutions posted help you out at all. It's a long shot as this link is for Apple users but it might point you in a direction you hadn't yet tried. All the best.
Sep 30, 2010 | Canon PIXMA MX850 Multifunction Printer
My canon MP610 printer is not responding after replacing ink
Try switch of computer and printer if not in printer list of printers. Unplug usb cable and start computer without computer connected. Them switch off computer again and plug in usb cable and then restart and after started switch on printer and Windows should find printer as a new connection and then you may need your driver disc to reset up.
Mar 17, 2009 | Canon PIXMA MP610 InkJet Printer
Canon mx850 series Error Number : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
I had the same problem. I had moved my printer and when I hooked it all back up, there was an annoying clicking sound, the "in use/memory" light was flashing and there was no communication with my pc.
This is a tad embarassing, but if it helps someone, so be it lol. I had plugged everything in without looking.... my usb cable was plugged into the phone jack >.<.
Check all your connections.... then check them again ;)
Nov 08, 2008 | Office Equipment & Supplies
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 05, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
CANON PRINTER PIXMA iP 8500 ERROR 300
Thanks for your posting in FixYa.
  1. Turn off printer
Dont forget to vote me.
Regards
Ellin
Nov 08, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
5,573 people viewed this question
Clive
Clive
old marine
old marine
