Question about Panasonic Car Audio & Video
I have a panasonic DFX150U car receiver and i need to know how to use all the functions mainly the equalizer
    Novelist:
  • 100 Answers
Http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-DFX150U this should be a link to the site to download the manual. Good luck.
-Andrew Hawkins
Posted on Aug 29, 2008
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
Sound is distorted after replacing the stock head unit with dfx150u
your stock speakers probally arent enough for the new unit.check your settings on h/u try to get the distortiton out
Nov 08, 2009 | Panasonic CQ-DFX150U CD Player
How do I connect my Yamaha EQ-70 to my Yamaha RX-V2400 receiver?
from your receiver; R&L PRE OUT to R&L LINE IN of Equalizer.
And - from Equalizer R&L LINE OUT to Receiver MAIN IN.
http://www.yamaha.com/yec/customer/hookupdiagram.html?CTID=5010070.
Hope this helps!
Aug 10, 2009 | Yamaha EQ-70 Home Equalizer
Need to reset owner ID on a panasonic tx-32lxd
Service Mode Function
MPU controls the functions switching for each IICs through IIC bus in this chassis. The following setting and adjustment can
be adjusted by remote control in Service Menu
How to enter SERVICE
In main menu, move to choose sound menu, set BASS to MAXIMUM, and set TREBLE to MINIMUM.
Simultaneously press " i " button on remote control and DOWN button (-/v) on the TV set.
Exit with off switch on tv.
When you next switch on TV it is as brand new giving you the option of setting pin number and user ID.
Mar 05, 2009 | Panasonic CQ-VD7500U 7 Wide LCD/DVD/SD/TV...
Trying to hook up 901's with a AVR2802 Dennon amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Nov 16, 2008 | Bose 901 VI Main / Stereo Speaker
Como conectar un ecualizador Technics SH-E51 a un amplificador Kenwood KA300
How do I connect my equalizer to my receiver?
There are two methods of connecting an equalizer, by either using the tape monitor or the main pre-in & output jacks. To connect through the Tape loop, connect the EQ L&R outputs to the Tape-in (play) jacks of the receiver, then take the EQ L&R inputs to the Tape-Out (REC) of the receiver. On the front of the receiver you will need to select the Tape Monitor to access the equalizer.To connect through main pre-out/ pre-in jacks, connect the EQ L&R outputs to the receiver main-in inputs (pre-in), then connect the EQ L&R inputs to the main out (pre-out)
Oct 05, 2008 | Audio Players & Recorders
Technics SH-8017 Equalizer
use youe tape out signal into the eq's main input and the eq'sout back into the record side of ur tape source.
Jul 28, 2008 | Audio Players & Recorders
Equalizer connections
Usually you hook your equalizer between the pre out and main in RCA jacks and then open the connection between the pre and main with a switch. If your unit doesn't have pre out/ main in jacks then I have seen it done by putting your equalizer between the tape in and tape out jacks and then select that tape function on your front panel. The tape out goes to eq. in and the eq. out goes to tape in. Good luck.
Jul 25, 2008 | Sony STR-DE485 Receiver
Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Nov 28, 2007 | Bose 901 VI Main / Stereo Speaker
Car Audio & Video Logo
80 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
