Question about Sony Mavica MVC-FD83 Digital Camera
Shutter speed I am new to digital cameras and I just purchased a Sony fd-83. The specifications say that the min shutter speed is 1/8 second and the max shutter speed is 1/4000 s. Nowhere in the manual or on the camera can I find how to adjust the shutter speed. Can someone help? Thanks Till
    Master:
  • 551 Answers
Hi Till. If I am not mistaken, the shutter speed on the FD-83 is automatically set and does not provide for manual override. I will check today with our product manager to verify this.
Posted on Sep 08, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How to set my cannon eos rebel xs to fast shutter speed
The max Shutter speed is 1/4000 to select this put the camera in Tv mode i.e. Timed value or shutter priority
May 19, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Under exposed pictures when using studio lighting with 5D
A black shadow at the bottom of the image is usually the result of using a shutter speed that is beyond the max flash sync speed of your camera. The max sync speed of the 5D and 20D is 1/200th. In a studio setting with wireless triggers there can be additional latency. Try using a shutter speed of 1/125th and see if that clears it up. You may be able to push it a little higher as pocket wizards are very good wireless triggers but don't use a shutter speed above 1/200th.
Jan 27, 2009 | Canon EOS-5D Digital Camera
Camcorders
Almost any new digital camcorder will work great, but you want to make sure it has a high speed shutter setting.  Set the shutter speed as high as possible (which means you'll need a lot of light... day light is perfect).  You're still only shooting 30 frames per second, but each shot will be sharper (less motion blur) as the shutter speed increase.  High-end cameras can go up to as much as 1/10000th of a second, but even 1/500 would be great.  Standard, default shutter speed is 1/60th.
For playback, you can use the same camera with a remote control.  Just press play, then just before the swing press pause.  Then use the frame advance button to move 1 frame at a time.  Multiple presses of the frame button will increase the speed... to slow motion.
Apr 24, 2008 | Video Cameras
D 80, controling shutter speed
dear hydet
use 'Program Shift'. This will change the values for both aperture & exposure, but keep the overal exposure value correct. Eg if the standard values are 1/60th of a second at f5.6, then rotating the dial in one direction will change the parameters (first) to 1/30th & f8, etc, and turning it in the other direction will change them to 1/125th & f4.
oke, post in me back
thx
cropp
Mar 16, 2008 | Nikon D80 Digital Camera with 18-135mm...
Sony MVC FD83
Something must be in there ! Couod one of your little kids have somehow put something in there which did NOT belong in there ??
Take a good working penlite...and LOOK inside the slot to see if there's some foreign object in there.
Feb 11, 2008 | Sony Mavica MVC-FD83 Digital Camera
Installing memory stick into a Sony Mavica FD-83...
There is absolutely NO way to use a Memory Stick with the FD83 camera. The floppy adapter will never work with a FD83. The camera OS does not have the required driver.
Sep 13, 2005 | Sony Mavica MVC-FD83 Digital Camera
Low lux mode FD83
I also, almost always use the low lux modes with that cam, that is, when I have a tripod or can keep the camera steady. Oh, and it s$cks for action shots, but for stills its great. I find that the lox lux mode actually reduces noise in addition to brightening the image and making the colors pop. Who woulda thought? It's a nice feature to have when the onboard flash is useless. Anyway, this mode apparently does use a longer exposure seeing how you get blur as the shutter speed is dropped. I'd say its around 1/3 to 1/15 of a sec (I wouldn't think it to be longer than 1 second). I really don't have a clue as its a preset, though. But, again, that mode saved that camera from being crapo (like the earlier ones before it), despite its limited uses (stills).
Long Exposures with S75
No, 8 sec. is the max. goto the S (shutter priority)or M (manual)setting on the camera and use the black wheel with your thumb to set the shutter speed.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Interlace Scan (IS) mode and the Progressive Scan (PS)
The Interlace Scan (IS) mode the camera uses a mechanical shutter with shutter speeds up to 1/640th second. It also uses the maximum resolution that is possible with the CCD (5.0 MP). In the Progressive Scan (PS) mode the camera operates with the electronic shutter with shutter speeds up to 1/4000th second and a 1/18000 second shutter speed (1/18000 in Shutter or Manual Priority modes only). In this mode the resolution is reduced in half (2.5 MP).
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Sony Mavica MVC-FD83 Digital Camera Logo
305 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
