Garmin nuvi 205W GPS Receiver Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Quick start manual - want to program garmin starting at another point, other than current location. How do I do this?
Anonymous
Level 3:
  • Master 1,514 Answers
  • Posted on Jul 21, 2011
Anonymous
Master
Level 3:
Answers
1514
Questions
Helped
332195
Points
3516
YOu can get the manual at http://static.garmincdn.com/pumac/2675_OwnersManual.pdf
You'll find details of how to change your home location on page 7
1helpful
1helpful
How do I save a new waypoint on my garmin 76cx?
Hi!
From your User's Manual Page 7:
You can create waypoints using three methods. Press the Enter/Mark key while at a location, create a waypoint on the Map page or you can manually enter lat/lon coordinates.
TO MARK YOUR CURRENT LOCATION
Press and hold the ENTER/MARK key until the Mark Waypoint page appears. A default three-digit name and symbol will be assigned to the new waypoint. To accept the waypoint with the default information, simply select OK.
To change any information, select the appropriate field and press ENTER to open the on-screen keypad. After entering and confirming the information you wish to use for the waypoint, select OK.
CREATING WAYPOINTS USING THE MAP
On the MAP page, use the ROCKER to move the pointer to the map item you wish to mark.
Press and QUICKLY release ENTER/MARK to capture the pointer location and open the information page for the map item.
Select SAVE. If there is no information for this point, a prompt will appear saying "No map information at this point. Do you want to create a user waypoint here?". Select YES.
If you require a User's Manual, you can view/download it from:
http://www8.garmin.com/manuals/GPSMAP76Cx_OwnersManual.pdf
Hope this is helpful to you.
Good Luck!
Feb 27, 2011 • GPS
3helpful
How do I change the start location?
The "current location" is based on the stellite tracking of your GPS. Turn it on OUTSIDE for 10-15 minutes and allow it to get a lock on the GPS satellites and it will get your actual location. There is no way for you to "force" a current location on the GPS.
Manual is available her:
http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf
Can't communicate between Garmin Nuvi and computer? Get an error message that says some devices have been found but none contain the necessary...
You must use the newest Software (free) from Garmin.
Start with the newest program for YOUR computer BEFORE you plug in your Garmin:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Computer can't locate connected nuvi 270
Are you using the latest Garmin program called WEBUPDATER Version 2.9.1.0 that was released about December 2009??
Try again:
Location is not shown correctly
everytime u turn the GPS device on it takes anywhere from 30secs to 4 mins to find and lock in the satellites . Once the satellites locked in it will be then start taking ur commands. In ur case u turned it off as u started driving and when u restarted it , it had a memory of where u turned it off and displayed u the location where u turned it off which was ur home, right, now if u would have waited till some satellites locked in , it would have then automatically displayed ur then current location. so next time when u start the unit (any GPS) wait till it locks in the satellites.
thank.
1helpful
Nuvi 260w no drivers and distance is off by 200 feet.
200 feet is not out of the ordinary for "Some" locations.
You do need to update it though using Garmins WEBUPDATER. Get it free here:
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Wont take a complete address. takes a different route to and fro . how can i set it to take me the same way both ways.how do i plan a trip with stops . do you have a manual. other than the quick start.
I don't know of any Garmin unit that can plan multiple stops. Problem with the Garmin, depending on your current location, it will go either the fastest time route, or the shortest distance. And sometimes, it can take different routes depending on what time of day. Most newer units take traffic into consideration based on time and location. You may want to play with the settings under avoidences.
2answers
Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
