Question about HP Photosmart 945 Digital Camera
Archiving photos
What is the best way to archive my digital photo files?
    Master:
  • 542 Answers
Archiving your images on a DVD is just about the best, most cost-effective way to organize and care for your pictures. Making your own DVDs is quick and easy and doesn't require much investment. And a DVD can hold up to seven times more than a CD, which adds up to about 15,000 photo-quality pictures per DVD! The best part? DVDs make storing and sharing photos a snap.
Posted on Sep 08, 2005
SOURCE:
Outlook 2010 archiving to wrong user
It looks like the folders were closed after archiving.
Try opening them again by using File, Open Data File and then picking the appropriate data file.
Apr 12, 2014 | Microsoft Outlook 2010
I can't read offline and any messages on screen, and can't send messages too.
Dear Friend,
Please download latest version of Yahoo Messenger....... and use following instructions -
Click the Messenger menu in Messenger.
  1. Select Preferences.
  2. Click the Archive category.
  3. Check the Enable Archiving option. Enable each item that you want to archive. If you'd like to automatically delete archives after a certain number of days, place a check in the box next to Automatically Delete Files Older Than and enter a number.
  4. Click OK at the bottom of the window.
Please Note: Uncheck the Enable Archiving option if you'd like to disable Archiving.
To view your archive:
  1. Click the Contacts menu in Messenger.
  2. Select Message Archive.
  3. A new window called Message Archive for {your ID} should appear.
  4. Select the archive folder you want to review.
To delete your archive:
  4. Select the Messages folder and then click the X button if you want to delete your complete Message Archive or select the desired folder and then click X to selectively delete.
A few things to remember:
  • Under the Message menu, you can reply, save, and print messages, as well as view your archiving preferences.
  • Under the Edit menu, you can copy messages to your clipboard or delete messages.
  • Under the View menu, you can enable timestamps.
Please Note: Archives (.dat files located on your system) are encrypted and can only be viewed by the Yahoo! ID that created them. These archives are stored locally on your system, so the conversations held on that specific computer are only accessible from that computer. Once archives are deleted, they're gone, and cannot be retrieved.
Please vote after working...
Best regards,
Pramod Bhikam Singh
Apr 22, 2011 | Yahoo Messenger
My images save at sizes of 3-4 MB!!! how can i get them to be (way) smaller files??? powershot SD790is digital elph
Your solutions are varied, but the results will be (mostly) the same. Option 1: Lower the resolution and quality settings on your camera. If you are seeing 3-4 MB per photo, then they are probably at least 4000 pixels wide, and your file size will be larger to reflect that. If you set the camera to a lower quality and or resolution, you will for sure save disk space. Consequently, you will also lose image quality. If you are mainly archiving the photos for the purpose of viewing them online, on your PC, or through a digital picture frame, this is no big deal. If you intend to print, especially a large print, you will see pixelation occur in the print. This will take smooth parts of your picture and chunk colors together in a "boxy" appearance. Your second option, is to import your photos in a program like Google Picasa or many other free options, and then convert your image to a compressed format, such as a compressed JPEG or PNG file. PNG files are usually the better choice for file size, but not every devices (frames, TVs, etc.) recognize PNG files. So you may want to stick with JPEG depending on your use for your photos. Additionally, you can lower the resolution of hi-res photos within Picasa (or its alternatives) after importing the photos. This is the preferred route as you can take every photo like you want to print it as a poster, and then choose which photos to drop the resolution. This gives you the safety of shooting each picture as if you want to keep the quality and then later decide which are worth archiving at what resolution. Remember, the detail in a photo also reflects upon its size, not just resolution, if you take one 12 MP picture of the sky and another of a bunch of different color balloons, the balloon will have more color data and thus a higher file size.
Mar 10, 2011 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Menory low on harddrive a220n
If your disk space is low on the Hard Disk drive, delete or move some files off. You can replace the hard disk for 30-50 dollars with a larger one. If it is low on memory (RAM) you can add more up to the system limit from several sources.
Thanks
Jan 06, 2011 | HP Pavilion a220n (DK218A#ABA) PC Desktop
How to save scanned image from MX310 to computer?
Save the scanned image as a TIFF for archiving. TIFF files can beresaved and edited without compression loss, thus maintaining the highquality of an image. If you are enlarging an original 4 x 6 photo to8.5 x 11, save the scanned image as a TIFF at 600 dpi resolution. TIFFsprovide more detail than other file formats. Scanned images for emailand posting on the Web, which are to be viewed on a monitor, should besaved as JPEGs at 75 or 100 dpi. JPEGs generate smaller file sizes,which download faster on the Internet. Increase the resolution to 150or 300 dpi only if you are emailing a scanned JPEG image for therecipient to print. Save JPEGs at the maximum quality setting.
Dec 16, 2009 | Canon PIXMA MX310 All-In-One Printer
I have an Olympus Digital Voice Recorder WS-311 M and a new Macbook Pro. I cannot seem to download to my Mac
http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1308&ct=all
"DSS Player Version 7 (Vista Compatible) Item: #147467-410
DSS Player version 7.x provides computer support for Olympus DS-Series, WS-Series and VN-3200 and VN-5200 PC digital voice recorders using Windows 2000 Professional, XP Professional, XP Home, Vista, and Windows 7.
Functions include USB file download, file playback, editing files, conversion of DSS files to WAVE format, and archiving files. The installed application provides for the purchase of an optional Plus upgrade that enables splitting and joining files, and compatibility with voice-to-text transcription software.
The CD also contains DSS Player for Mac that provides computer support for Olympus DS-Series, WS-Series, and VN-3200 PC and VN-5200PC digital voice recorders on Macintosh platforms using Mac OS 10.3 and later, excludes: DS-3000, DS-2000, DS-660, DS-330, DS-320, DS-150, DS-10 and DM-1. Functions include USB file download, file playback, editing files, conversion of WMA and DSS format files to AIFF format, archiving files, and splitting and joining files. This MAC software version is not compatible with older foot switch RS-25, only the RS-27.
Item #147467
Opened software cannot be returned.
Price: $29.99
Sep 24, 2009 | Olympus WS-311M Digital Voice Recorder
Archive Calendar
check with microsoft for an update, any problems with outlook is microsoft's baliewick. www.microsoft.com/outlook upgrade.
Apr 29, 2009 | Computers & Internet
Archiving Digital Camcorder Video - Ideal Formats
Let's try to bottomline this. If you want said DVD to play in most players, you'll be encoding the video according to standards. The current DVD is MPEG2. At the current time, most people just have DV camcorders so you don't see the generational loss as you move the video from DV to DVD. At least I don't.
Sep 13, 2005 | Sony DCR-HC15 Mini DV Digital Camcorder
E-mailing photos
JPEG format storage is ideal for posting your photos to the Internet and for e-mailing them to friends. (It’s also useful for archiving when you've finished editing them and need to save storage space.) The compressed images still look good on-screen and contain a relatively large amount of information in the shrunken file. JPEG storage is great for maximizing space but not for maintaining image quality. If you want to get smaller files for archiving, use minimal JPEG compression (high quality/low compression). The ideal compression is lossless, which means there's no discernible drop in image quality even though the file size has decreased.
Sep 08, 2005 | HP Photosmart 120 Digital Camera
HP Photosmart 945 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
