Can you put a memorex 2 hd 3.5 in your laptop to scan pictures? if so how do you remove the disk from the plastic cover?
    Scholar:
  • 113 Answers
Do you mean a 1.44mb floppy disk? If so you need a 3.5 inch floppy drive, "you don't remove the disk from the plastic cover"
If the laptop doesn't have a built in floppy drive, you can buy a USB external one.
You don't say if you wish to scan to the floppy, or get photographs from it!
There is no point in scanning to a floppy these days as it's capacity of 1.44MB will hold very few high resolution photos.
if you are trying to retrive photos from a floppy either get the USB floppy drive sugested above or use a PC which has a floppy drive & transfer to another medium which can be read by your laptop (SD card, burn to CD) or of course email the scans to yourself.
Posted on Aug 28, 2008
  • 95 Answers
You can't remove this cover, if you do it will be damaged permanently. If your laptop have a floppy drive then you can do , if not there is a few ways around it, put the floppy in your desktop floppy drive and copy pictures to my pictures folder and then send them to your email address or place them as documents and do an attachment, but you must be able to insert this 2hd in a (floppy drive) or you can copy this disk to a memory stick!
Hard disk
flip over laptop; you\'ll see a cover with 2 screws; remove cover; you\'ll see caddy(had pull strap on it) theres your HD
Dec 21, 2012 | HP Pavilion DV9720US Notebook
Why is picture scrambled on my memorex dvd mvd2016
The MVD is a progressive scan DVD player if your TV is 1080i or shows interlaced images only and doesnt have the option for progressive scan this would be an issue. I would suggest trying this DVD player on another television first. Also what is the model of your television?
Another issue is if you have and HD TV and are hooking up the A/V jacks to the HD component inputs this would also provide a jumbled picture. It would be a good idea to check and make sure that the A/V cabled are inserted into the correct input.
May 05, 2011 | Memorex MVD2016 DVD Player
I have put a nother hard disk western digital wd800j-75msa3 but when windows xp home edition service pack 2 is loading start op i get then a blue screen that says stop check for viruses or hard disk...
First thing that I would do is this, scan the HD for virus using another PC AND use another Antivirus file, like Norton 360. I trust Norton before I trust AVG. If Norton finds any virus's, it will delete it, if it's set up right or it will ask you what you want to do? Once this is done and all virus have been deleted try runinng it again. If this dose not work, there's always "Reformatt" You can remove the HD and use USB ExHD, just conext the 2 together and run the scan. DO NOT OPEN IT. Run scan first.
Apr 17, 2011 | Gateway NV5815u (LX.WDC0X.002) PC Notebook
ERROR CODE E602-0003 What is this?
E602
1) Are the connection and the cable of the connector (J1017) on the main controller PCB and the connector (J1551) on the hard disk drive normal? NO: Correct the cable connection.Hard disk drive (HDD), Main controller PCB
2) Try replacing the hard disk drive and downloading the system software.Is the problem corrected?
YES: End. NO: Replace the main controller PCB.
3) HDD unit.
Remove the rear upper cover and the reader rear cover. Remove the three screws, and detach the cover, Remove the two screws and disconnect the two connectors then, remove the HDD unit. Remove the six screws and detach the HDD When mounting the HDD unit,be sure that the flat cable is under the plastic sheet of the HDD upper case.
Solution 1# :
It can be a Sector Problem ,to resolve it just press 1&9 keys at the same time the machine started the HD Diagonose and it repared the sector error without replacing the HDD .
Solution 2# :
try to go in to disc check service mode to clear the sectors ,this should work if it doesnt you will need to replace the hard drive .
Solution 3# :
Try HD clear & then HD check for every sector in service mode. Then try to upgrade system software;If nothing works change hard disk ,format & install system software. Posted by Kuyung at 5:50 AM icon18_edit_allbkg.gif Labels: error code 602-0003 IR5000, error code 602-0003 IR6000
May 07, 2010 | Canon imageRUNNER 5000 Copier
I am trying to remove the HD, so I can connect it to a SATA/IDE to USB adapter. Not sure how to remove the HD.
Hi
thank you for your query
Please do the following
1) Turn the laptop over on its front
2) You will be presented with the bottom of the laptop, the screen hinges should be facing the front
3) In the bottom left hand coner there will be 2 screws, screwed into what looks like a little black plastic cover
4) Remove these 2 screws and using a flat bladed screwdriver open up the plate
5)The hard drive will be located underneath this cover
6)Simply pull the drive to the left or right (depending what side the connector is on), and pull up and out
This will remove the hard drive, reverse the above if you wish to reinstall
I hope this helps
Mar 04, 2010 | Toshiba Satellite M45-S265 Notebook
June 22, 2009 Dear Person, I have an HP-Compaq laptop computer, business model nx9010, s/n CNF3520KL4, with a failed hard drive. I am unable to remove the drive. I have removed the three (3) visible screws...
http://www.karlin.mff.cuni.cz/~motl/hp-keyboard/manual4700.pdf
PAGE 39
1. Unplug the AC adapter, if present, and then remove the battery.
2. On the bottom of the notebook, remove the hard disk drive rubber screw plugs and
M2.5×6.0mm screws. (The number of plugs and screws varies by model).
3. Carefully pull the hard disk drive out of the notebook.
4. Remove the four M3.0×4.0mm screws from the hard disk drive and hard disk drive tray,
and then lift the drive out of the tray.
5. Remove the connector bar from the hard disk drive.
The manual does have little picture to help you. The link above is to download the service manual.
Jun 23, 2009 | HP Compaq Business Notebook NX9010
My acer 5620Z laptop cannot find its operating system
you can do check HD follow me:
1) open the cover at back of laptop
dc0d736.jpg 2) take out HD body see picture
5d35e3d.jpg 3) put it back in same way, then power on if bios find HD, the error message should be gone.
4) if still show error, you need change other HD, till the bios find out HD drive.
here you can download the service manaul to reference.
hope you fix it well, any question ask me any time please
May 13, 2009 | Acer Extensa 4620 Notebook
Fan blade noise
This is most of the time due to excessive dust covered on processor heat sink try cleaning in side with pressure air by removing keyboard.
Mar 13, 2009 | Acer Aspire 5050 Notebook
Replace Memory
Link
click on the links on the page for removing dimm A
1. Preparing to work inside
2. Removing hinge cover
3. remove keyboard etc.
Aug 21, 2008 | Dell Inspiron XPS M140 Notebook
I started a virus scan on my laptop as i left to go out. when i came home a few hours later, the laptop was switched off. i couldn't switch it back on because the hard drive was dead. i can only access...
Hello
seems like your hardrive is broken. one thing you can check is to remove the harddisk and check the IDE connectors and put it back it can be something loose. the other thing is to remove the plastic under the laptop so you see the HD and feel if the HD make any noice or vibrations when you start the computer.
Aug 13, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
