Question about Apple PowerBook 520 (M2597B/A) Mac Notebook
Apple PB 520
It's old, I know, but the screen has begun to flicker as if something had become loose. Can I open it and see if something disconnected? How?
    Novelist:
    Champion:
  • 382 Answers
Sure, the warranty on that machine was up over 10 yrs ago. Those laptop had a going life of 7-8 years, the internal hard drive that shipped with it, 4 at the most. It's called wear and tear and parts being outdated. So it comes down to how much your time is worth, what is it you choose to gain and the law of diminishing returns.
Posted on Sep 01, 2008
My asus screen keeps flickering
I would open the back cover with a flat metal opening tool like this: http://www.ebay.com/itm/Tech-Metal-Spudger-Opening-Tool-for-ASUS-Nexus-7-1st-2nd-Gen-ME370T-ME571K-NEW-/161561753109?ssPageName=STRK:MESE:IT
then disconnect the battery 1st before anything. Check the LCD cable which is silver and runs from the MB to the LCD top to bottom over the battery. It looks kind of like a stick of gum. They often become loose and just need to be reconnected and secured better with some electrical tape. Be careful with the clips. I'm almost certain that is where your problem is and you should be able to fix it without much trouble.
Good luck
Apr 20, 2016 | ASUS MeMO Pad 10 ME102A-A1-GR 10.1" 16 GB...
Blinking screen off
First, restart your iPad.
If the blinking continues you will have to take it to an iPhone/iPad specialty repair shop because the problem is it has probably been slightly damaged some way and the blinking screen means that the screen has been damaged in one area
Sep 02, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My bike chain always become loose ??
Both, chains and sprockets have "pitch" if they are not the same pitch the chain will become tight then loose breaking the bearings and destroying the chain
Apr 01, 2014 | Regina Chain 520 ZRD Chain and Sprocket...
One two touch will not boot, power switch just flashes
Beep codes are nice but you have to know who makes the BIOS to use them. Check the RAM and see if it is loose.
Feb 05, 2014 | Packard Bell Computers & Internet
How to solve a flickering screen for toshiba satallite m200? as i open my laptop its hang and the screen is flickering...
@crisanne_21
Most of the time, that cause of that flickering screen is a defective LCD flex cable or sometimes called LVDS cable (this is the cable that attaches the LCD panel to the motherboard - it can be caused by a loose connection or simply, it just may have worn out due to opening/closing the lid). The only way to fix that is to replace disassemble the computer and check if there's a loose connection on that LCD cable. If disconnecting / reconnecting the LCD cable doesn't fix the issue, you might need to replace it Disassmebly guides can be found here.
Good Luck
Sep 05, 2011 | Toshiba Computers & Internet
The display on my laptop has stopped working. All I get is a blank screen. A couple of days before lines appeared on the screen and if you moved the screen it flickered on and off....any ideas?
there is a ribbon connector that runs from the labtop to the screen .... eather it has become loose ro disconnected or the screen has shorted out the first of the two sounds like the problem
Mar 01, 2010 | HP Compaq Presario CQ50-110US Laptop
Trouble with screen (powerbook G4 15" 1.67 GHz)
Well the issue isn't with the graphic card. It actually is the screen of the PB (PowerBook). I had somewhat of the same issue about 6 months ago on my 17" PB G4. But when it started to do that with mine, the screen would also make sharp vertical lines when opening and/or adjusting angle. So before my Apple Care warranty expired I had the screen fixed FREE. So, if you do have your Apple Care warranty still and not expired, I'd suggest to you to find a Apple Certified computer shop or the nearest Apple store and drop it off with the explanation to have the screen replaced. Otherwise you will have to pay a pretty penny.
And if you do not have the warranty then i suggest you not to take it to a Apple store due to the extreme cost of a new screen on an old machine. Instead goto ifixit.com. This site is great for anyone who has anything portable from Apple (including the non-portable MAC-mini) for replacement or upgrade parts, cheaper and also helps with the install (DIY instructions and pictures to go with it)
- Luke
Jan 28, 2009 | Apple PowerBook G4 Mac Notebook
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Acer Aspire 5720Z Notebook - Screen flickers, goes blank then comes back on when screen/lid is adjusted
It sounds like a loose connection or a snapped dry solder joint leading to the backlight. On notebooks and LCD monitors, the screen consists of a florescent panel behind the screen which shines a light similar to a florescent tube through the screen. From your description, it would appear that something is becoming disconnected there.
A local specialist in flatscreen repairs should be able to fix it if it's nothing too major. Try and find one who has a certification to work with Acer to avoid voiding the warranty. If you live in Ontario, where I live, I can do a search to see if I can locate one (please either use the ask button to contact me directly or leave a comment on this ticket) but I have no details of potential repair locations outside Ontario.
May 29, 2008 | Acer Aspire 5100 Notebook
I have the same problem. It happened to me about half a year ago and reinstalling the OS solved it. So it's by no chance a hardware problem. I have a Acer TravelMate 6291. It must be some kind of a software problem, but don't know which one :-(
May 29, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Apple PowerBook 520 (M2597B/A) Mac Notebook Logo
76 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
