Question about HP Photosmart 945 Digital Camera
Batteries
What's the best battery to use in my HP digital camera? Is it OK to use regular alkaline batteries?
    Master:
  • 542 Answers
Popular alkaline batteries are inexpensive and can be found anywhere, but their power is consumed at a rapid rate. If you're using all of your camera's features, you can deplete a set of alkaline batteries in about 30 minutes! You should consider spending a little more up front for a battery charger and some rechargeable batteries. Many cameras (including many HP Photosmart digital cameras) work with the popular, rechargeable nickel-metal hydride (NiMH) batteries. They are inexpensive and environmentally friendly, and they give you more pictures per charge than any other battery types, except for lithium-ion batteries—another battery of choice for many HP Photosmart cameras.
Posted on Sep 08, 2005
SOURCE:
Is it necessary to put any specific type of batteries?
Yes, on Kodak cameras, for instance, they recommend LiIon batteries which have a higher voltage.
Some camera brands work off of regular alkaline batteries, though.
What kind of camera do you have?
Jan 13, 2011 | Cameras
Vtech Kidizoom camera. Have changed batteries but unit is not even switching on. Son has had for just over a year and it has been dropped several times.
Try cleaning the battery contacts inside the battery compartment. Do this with a cotton swab "dampened" in rubbing alcohol. You may also want to clean the battery contacts and the charging station if so equipt. Thanks, Dana
Jan 06, 2010 | Vtech Kidizoom Digital Camera
Camera will not power on
Are you making sure that you are using Alkaline batteries? Regular batteries won't work. Even rechargables will only work if you first put in alkalines and change the battery type in the menu, then put in the NiMH batteries (not NiCads).
Mar 22, 2008 | Samsung Digimax S730 Digital Camera
Flashing Light
I have had a HP Photosmart 945 for a few years now. A few days ago was the first time I saw my camera experience the problem described above. I thought something is wrong with the on-bard logic.
Replacing my batteries (4x2300mAh NiMH AAs) with four other freshly charged batteries of the same kind didn't fix it. The camera's LCD kept flashing on and off for almost an hour until my family got tired of it and turned it off by removing the batteries.
I just replaced the rechargeable batteries with four regular alkaline batteries and now suddenly it works. Go figure.
The moral is that changing the batteries sometimes helps. When it works, it will get your camera going for a while. The problem, however, doesn't seem to be battery-related or I would have seen it a long time ago with smaller-capacity batteries like alkaline AAs. Something is very wrong with the camera itself, that much is clear.
Best-case scenario now is that I have an unreliable camera that can give out at any moment. For example today it died in mid-shot and almost spoiled a family event. For me the solution was "get a non-HP camera".
I hope this helps someone out there.
Dec 19, 2007 | HP Photosmart 945 Digital Camera
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Batteries
No, the suggested batteries to use would be the NiMH batteries. The NiMH batteries are rechargeable, economical and last much longer than alkaline batteries.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
HP Photosmart 945 Digital Camera Logo
87 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
