Question about U-Line Icemaker
U line ice maker
Punched hole in bottom of ice maker
  • howardgreenl Apr 29, 2009
    water seems to drip from bottom front and rear of ice maker;also noticed that icemaker itself was not installed levei
    Problem Solver:
  • 10 Answers
Where at? if it is in the water resevoir rough it up and JB weld it
Posted on Dec 19, 2008
GE refrigerator PFCS1RKZSS no ice
check for ice build up in the lines to see if that's blocking the air. Make sure your water and your solenoid are working.
Dec 11, 2015 | GE Refrigerators
Water keeps flowing into the refrigerator from the back in the middle
Turn off the ice maker water supply. You either have a bad water valve or a bad ice maker. To determine that you needs ta do some checks. Disconnect the power connection to the water valve and read the voltage. If it reads 120 vac then replace the ice maker. If it has 0 voltage coming from the plug replace the water valve.
Nov 02, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Water is dripping into the bottom of my fridge. I have cleaned and vacumned the coils. How do I access the drain to see if it is frozen?
Remove the ice maker and back panel in freezer.1/4 inch nut driver to remove screws. there are 3 screws for the ice maker 2 on the back wall and 2 on the bottom panel. Use a hair dryer to melt ice block.All water will flow down into drip pan under fridge. May overflow use a turkey baster to remove water from pan. Pour hot water onto drain until the water flows freely into the pan.
Jun 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped making ice and now is leaking from the back of the fridge.
Here is what I think it might be: The water valve has a slow faucet like drip that forms a stalagmite in the fill tube. When the ice maker calls for water the water goes out the backside. OR it might be the line has a hole in or has come off the fill tube in back of the ice box. Solution: replace water valve and blow dry fill spout to get out ice.
Apr 01, 2010 | Maytag 24.8 Cu. Ft. Side-by-Side...
I have a maytag fridge and the ice maker is on but it is not making any ice. what is wrong?
You most likely have a bad ice maker, but it also could be the ice makers valve solinoid is bad as well. You can check your ice maker by removing the front cover and at the bottom right about 1 inch up from the bottom you will see 2 holes 1 of the holes will have the letter T next to it. If you take a wire that is stripped of it's insulation at each end and put one end into one hole and the other end into the other hole it will bypass the thermistat of the ice maker and make it start. If it satrts and runs then calls for water near the end of the cycle and stops then both the icemaker and the valve are good and this would mean you have a cooling problem. A ice maker will only attempt to make ice when the thermistat of the ice maker reaches about 18 degrees.
Mar 13, 2010 | Maytag MFD2560HES Bottom Freezer French...
I have an U-line combo 75A and the ice maker(part number 400) has started overfilling. When water enters the ice maker, it runs out the overflow hole. Any suggestions?
few thing can happen, bad thermostat it caused the ice maker stuck in harvest cycle, short in ice maker defrost heater, bad water valve switch or the overflow hole drilled to low, it should be 1/4 inch below the top, I seen some of them drilled 1/2 inch below and it caused water leak.
Feb 24, 2010 | U-Line Uline Origins Series...
Ice maker not making any ice!
it either is the water vavle burned out or the ice make went out usualy that is a common problem when the line freezes up to test the ice maker there take the front cover off ice maker then there should be two holes in the front a hole that has m and the on next to it put a jumper wire in that hole if it dont rotate the ice maker is bad. or if it is the other kind of ice maker take a flat head screw driver and turn the screw with on the motor gear clock wise keep turning it until it runs on its own you should get the same results like the above if ice maker test good the water vavle is bad check make sure you have no restrictions in the water line take the line off the vavle and let it run in a bucket to see what kind of water pressure you have it should come out fast
Jun 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker
We had a similar problem when we first purchased ours. It turned out that where the water line had been punched through into the house line, the punch ended up having to be backed out a little and then punched through again. The initial installation had not pushed through enough. No problems since. Hope this helps.
Mar 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
U-Line Icemaker Logo
57 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
