Question about Sony Handycam DCR-TRV480 Digital Camcorder
Sony DCR-TRV480 Tape Compartment not wanting to close
I seem to have the same problem as alot of other users out there. Camcorder not recognizing tapes, and tape tray not wanting to close. I saw you offer a service manual for this unit, and wanted to know how I might get a copy as well.
Thank you,
jjcurry at gmail dot com
    Problem Solver:
  • 3 Answers
This is what worked for me. I recharge the battery (with the tray still open), then I removed the battery. Replaced the battery and tried again. It worked this time. Apparently, it is a problem relating to the battery being fully charged. Good luck.
Posted on Mar 14, 2009
I have experienced the same problem. Like Microdac's solution, I recharged the battery, removed the re-charge cord, switched the unit on and, suddenly, the tape tray retracted and the camera became operable again.
Posted on Jul 05, 2009
I didn't even have to recharge mine. I just took the battery off for a minute and put it back on and it worked. I was just getting ready to take the whole thing apart to see if something was bent or something. Thank you so much. What an awesome resource
Posted on Jul 21, 2009
I've shared a solution for a semi-related problem where the system won't read a specific tape. Here: http://www.fixya.com/support/t764138-reinsert_cassette
That problem and this one have happened simultaneously to me.
However, if you are ONLY getting the stuck door problem, where the tape door is in the open position and the mechanism won't automatically, nor forcefully, close again (even though the eject/open mechanism still attempts to open) YES it IS as simple as popping the battery off and putting it back on. It should close fine after that.
I just confirmed it again right now, as the problem has returned to me a couple years later.
Posted on Sep 19, 2010
4 Suggested Answers
SOURCE: my camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Posted on Apr 26, 2009
SOURCE: I have a Sony DCR-TRV250 Digital Handycam
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Posted on Nov 17, 2009
SOURCE: loading tapes
Sony HDR models that the carriage won't close is caused by the mode switch on the chassis. The mode switch controls the cameras function for loading and loading of the cassette. Basically tells the electronics what is happening. This becomes dirty and causes the chassis not to complete it's cycle on eject. Thus staying open. It has no idea where the mechanism is at this time. It can be cleaned and realigned but the chassis needs to be removed to get at it. Definitely a service depot repair. Sorry!
Posted on May 02, 2011
Pc does not recognize sony digital 8 DCR-TRV480 when I hook via usb. what do i do now?
I always use ulead software otherwise you could have a digital interface problem . Is there a comp usa ,frys or similar place you can take your camcorder to to hook up and test it?
Apr 22, 2010 | Sony Handycam DCR-TRV480 Digital Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Compatability issues with sony handycam DCR-TRV480
Click Sony Support and download Vista updates for DCR-TRV480 camcorder.
Mar 27, 2009 | Sony Handycam DCR-TRV480 Digital Camcorder
Tape compartment will not close
This happened to my sony DCR-IP7E, I had to have this repaired by a camera shop of £129.00 with 12months gtee, work like a new one
Dec 30, 2008 | Sony Handycam DCR-IP7E Micro Digital...
My Sony Handycam DCR-TRV480 needs to be put in VCR Mode...
our camera is similar to yours, the switch you switch it on with also goes the other way, this is the vcr mode
Nov 17, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
PC won't recognize Camera
Try pinnaclesys.com. They have some trial software you can use.
Jul 15, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
Sony dcr-trv480 video camcorder error
I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
May 04, 2008 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape compartment won't go back into camera
hold it down till it gos back in if it dont go back in let go than hold it down
Dec 15, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
Sony Handycam DCR-TRV480 Digital Camcorder Logo
504 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
