Question about Haier Dishwashers
Water came flooding out and then when we turned it back on it just beeped and wouldn't shut off on it's own
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Sounds like the drain at the bottom of the dishwasher may be clogged! Or the water line in has broken or sprang a leak from down below! Where was the water coming out of???????
Perhaps you should try service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
Dishwasher wash light flashes
It might be helpful if you are able to identify the country where you are located. I am unable to locate any specific references to this dishwasher model on the Siemens website.
In the meantime, my observation is that the flood switch is coming on. This means the water leakage detection device that is hooked up to the dishwasher is triggering and causing the water inlet valve to shut and run the drain motor in the belief the dishwasher has flooded. These dishwashers of European origin usually have the leak detector circuits hooked to the inlet water hose. Even if the hose is crimped or crushed can cause such behaviour.
Apr 16, 2014 | Dishwashers
Is it possible for a water pressure surge to flood a GE Washer?
If you damaged the inlet valve on the machine with water pressure it would surely leak water into the tub even when not in use.If it was a lot of water it may have over filled. That would indicate a pressure switch failure. I would expect to find the hose that goes from the pressure switch to the tub or possibly the pump if it's a front loader, either damaged or disconnected. As a rule pressure switches don't have a high failure rate. So examine the hose first. Let me know what you find.
Jan 27, 2013 | GE Washing Machines
Red and orage lights are on - continuous beeping
It would be helpful if you are able to record the lights that are blinking.
Most likely the flood switch at the base of the diswasher under the bottom drawer has tripped. There is water leakage caused either by a broken hose or broken drawer lid seal.
The easiest way to confirm is to turn the power off at the power socket and shut off the water inlet tap. Pull open the bottom drawer and use towels to dry off the base. Use a hair dryer to fully dry the base. The flood switch is located on a small circuit board in the middle of the base. Wait for a couple of hours and then turn the power and water inlet back on. See if the beeps stop.
Dec 18, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hoover HED 6612/1-80 dishwasher all four lights flash and beep whilst the machine drains, after a couple of minutes the beeping stops but the four lights glow. Cannot reset to cancel. Also still makes...
Not sure if you have got a user manual for this dishwasher. You can download one from this site.
You have a flood situation inside the dishwasher. See page 12 of the manual. There may be no water at the bottom of the machine but there is some overfill occuring. Also see error codes on page 13. This can be either because the flood detection circuit is faulty and giving false trigger or there is water in the base of the dishwasher housing due to leaking door gasket or hoses.
Some things to try. Turn mains power off and back on and see if there is any difference.
If not, then turn power off and pull dishwasher out from the kitchen benchtop. Put a few towels on the floor and tilt the dishwasher side to side on the base and see if any water comes out. Wait 5-6 minutes and turn power back on. See if it makes any difference.
Dec 15, 2010 | Hoover Dishwashers
My alarm wont turn off. my car wont start. its a 2004 tiburon.
With alarm activated your ignition is disabled.Find the combination to disable it.With GM's you hold opposing buttons on the fob till it beeps twice. The dealer should help for no charge.
Feb 28, 2010 | 2004 Hyundai Tiburon
GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Jan 18, 2010 | Dishwashers
Flood switch
I had the same problem and I fixed mine. It wasn't hard at all. First, make sure power is off either unplug or shut off breaker. Next, open the lower drawer and on the sides toward the bottom you will see a circular recessed pin with a flat slot. Without forcing, wiggle the door down. When you get it off you have to remove the wire harness, just unplug it. Now, on the sides at the bottom, you will see where the drawer fits on the slid rail. Push the plastic button slightly to release the lock for the slid rail to the drawer and push the slid rail all the way back as to release the drawer fronm the rail. Be carefull when you release one side as to hold it up still while removing the other one. Now, flip the drawer on its side and try to get it as far out of the way as possible to the right of the unit. You will now notice a plastic cover at the back left of the unit. This is where the flood swith is. Remove this cover by sliding to the right. The will be water under the circuit board you see. Soak up as much as possible and you can use a hair dryer to get the tough spots. Now try to find the resson for the water. I had a mouse living under mine. Look for a break in one of the hoses. After all dried up turn power back in before reinstalling lower drawer. If dried properly, the dishwasher should stop beep beep beeping. Now turn water back on and run upper drawer. Inspect hoses again. 50/50 chance. If now water, reinstall lower by replacing plastic cover, place drawer on rails and slide all the way back. It should click back in if on rails correctly. Now install the door face, line up tabs into drawer, and slide up. Align holes for recessed circular pins and just push them in. Test lower. Thats all I got, Hope it helps.
Oct 03, 2008 | KitchenAid 23 in. KUDD01DPPA Stainless...
Dishwashers Logo
206 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
