Question about AOpen AX4SG-UN Motherboard
Won't go into Bios or display anything
I switched out the motherboard on a socket 478 computer with a 3.2 ghz chip and hooked everything back up and turned it on and the standby light comes on and both fans, but no picture or bios setup. Any ideas, I tried to jump the cmos, but that did nothing. The board is different than the original, but it supports the p4 chip up to 3.2 and the hard is good, but the darn thing will not start up to get the computer and peripherals talking again.
    President:
  • 2,351 Answers
Hi kwilson709, you sound like you know what you’re doing. Did you hear any beeps when you first started up the system?
Your must use the Intel (Northwood) CPU on the AOpen AX4SG-UN.
Make sure the 4-pin 12V. ATX Power Connector is seated & locked, same with the 20pin ATX main power connector. When you clear the cmos jumper, pg 24 in your manual. Remove the battery & check its voltage for 3 volts, if it reads anything less replace the battery.
If your graphics card is an add on & not integrated on to the motherboard, remove & blow out the slot with canned air & clean the contacts with a couple drops of alcohol on a cotton swab or to & reseat. Do the same for your memory. If the graphics card has dual VGA out puts check both for possible display. Make sure the monitor works.
(One never knows). Try one DIMM if you are running two DIMM's or more. If all of the above fail, it’s suggested that you remove the motherboard from the case & lay it on a table with a piece of cardboard under the motherboard. Hook up your power supply, graphics card (If you’re using one), memory (One DIMM & hard drive, mouse & keyboard. Once everything is connected short the two pins for power on with the tip of a pen to start up the system. Check for display. Still no display? (Only if you have one), try a lower MHz compatible CPU. Other than what’s mentioned above I'd say it’s the motherboard. (Testing the motherboard out side of the case is used to eliminate a possible case issue).
Mike
Posted on Aug 29, 2008
I could use a diagram of the mother board for a Pentium 4 2.4 Ghz processor. I picked one up second hand to replace my old processor
If your processor 2.4 Ghz HT you need socket 478 motherboard,System bus 800.without HT you need 533 FSB Motherboard.You can buy easily.Where you live? I do not know.China are available made 478 PIN mother board.
Mar 18, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Dell Dimension 4300 PC Processor upgrade
if the sci36-r13 is the stock mobo that came with that pc it isnt worth upgrading
pentium 4's use the LGA-775 socket this is compatible with all pentiums and core 2's (not includeing core i7), so you could put in a core 2 quad if you wanted to but it would not make much difference to performance because your motherboard would not be able to handle some of the fetures
your ram would also reduce preformance
if you wanted to upgrade that computer you would have to replace everything but maybe the case
Oct 12, 2009 | Dell Computers & Internet
Have a 2.8 ghz 478 chip, but ive never seen a pinless chip???
I do not know of any adaptors.
You have two options
Get a board that takes the CPU
Get a CPU that fits the board
Sep 11, 2009 | Intel Motherboard
NO BEEP, NO DISPLAY EVEN REMOVING OF RAM.
are you using socket 478 motherboard or socket lg775 motherboard? if lg775 mobo you using try to remove the cpu heat sink and put it back again make you put correctly lock it perfectly and try to switch it on
Mar 12, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I have an asus p48vx-x motherboard
you may check
1) your Intel pentium 4 3.2 GHZ cpu socket 478 processor #sl7nb what's FSB?( see on the chip surface, if 533 FSB can use but 800FSB could not match your motherboard if which is not support 800 FSB. that's why no display.
2) check RAM stick speed, try to increase a level, for example 266 to 333.
is this helpful please feedback thanks
Feb 12, 2009 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
No display
No, it is a motherboard processor socket problem, repairable only with a new motherboard. Can you give me motherboard details to compdoctor2005@btinternet.com
Dec 13, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
For my 1990 honda accord my computer light on the floor flash 15 time and i would like to know what part i need
This is Neeraj from india, when i on the pc, bios is displaying on the screen then i restart the computer bios not displaying. i remove ram and plug it again in the socket then its showing. is it motherboard/ram/processor prob..........using motherboard mercury pi845avg.........(478 pin socket), pls guide me whats the actual probb....
Email : neeraj.priyadarshi@gmail.com
mobile 09818492150
Jan 13, 2008 | Computers & Internet
Bios recovery for mother board ecs rs482-m
http://wiki.rom.by/index.php?title=Art_of_BIOS_flashing
Oct 04, 2007 | EliteGroup ECS P4M800-M Socket...
AOpen AX4SG-UN Motherboard Logo
162 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
