Question about Sylvania 6427TE 27" TV
Elongated picture on Sylvania 27" Model # SRT2232S
The picture appears to have stretched vertically and folded over on itself at the top of the screen. Seems like a simple vertical adjustment would fix the problem, but neither the remote nor the tv itself has this feature. Can it be fixed that way, or is the tube shot?
  • toddyhawk Jan 28, 2009
    our sylvania 27" is only about 4 years old but the picture also is bending in on the sides ... is the tube on the way out? is there a warranty? is it better to buy a new one or fix it?
    Problem Solver:
  • 25 Answers
There is a vertical adjustment on the picture tube it's the yoke as it's called but you can adjust it so much..but it does sound like the tube is on it's way out
Posted on Aug 28, 2008
Sylvania SRT2232S 32" was working
The problem is in the vertical deflection circuits which is responsible for giving a full picture. Since the set is 8 years old the money would be better spent on a new tv since more frequent break downs in other parts of the set would be more likely due to age.
Sep 15, 2011 | Sylvania SRT2232S 32" TV
Sylvania 6432TD turns off within a second of turning it on
Had same problem Sylvania SRT2232s 32"had to keep powering on and off until it warmed up enough to finally stay on. Problem was the 100/50 & 1/50 filter cap took it to local repair total cost to fix was 74.52 works better than ever
Mar 06, 2010 | Sylvania SRT2232S 32" TV
I HAVE A JVC AV27D302: THE PICTURE IS FOLDED OVER
For how many years this TV with you? Most tv now a days after few years of using vertical IC solder started to dry(dry solder) you can try to re-solder or you may check also two capacitors (100uF/35V) for most JVC model has this symptom with this parts changes its electrical characteristics. If still problem persist replace vertical IC. Hope his helps, Good Luck
Feb 14, 2010 | JVC AV27F476 27" TV
Needs vertical height adjustment
Is the picture stretched or shrinking and is it distorted or have lines? There are no vertical Height adjustment the circuit is prest and there is likely a problem in the vertical o/p circuit.
The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 28, 2009 | Sylvania SRT2232S 32" TV
Sylvania SRT2232S Powers On, No Picture, High Frequency squeal
Hello there. I'm sorry to say that it sounds as if the element that actually energizes your screen is bad. It is most likely overheating. or quite poosible the power converter lost a resistor or 2.
Nov 27, 2008 | Sylvania SRT2232S 32" TV
Elongated picture
There is a bad capacitor in the vertical circuit. If you feel comfortable working inside a set and can solder, update this and I'll try to get the specifics for you.
Dan
Aug 28, 2008 | Sylvania 6427TE 27" TV
32" sylvania TV thin line
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
Dan
May 07, 2008 | Sylvania SRT2232S 32" TV
Tv problem
Bad capacitor in vertical output IC circuit + check power supply
Last, replace IC.......................T.
Nov 09, 2007 | Philips 27PT6441 27" TV
Sony 27" picture quality
You probably have a leaky or open electrolytic capacitor in the vertical circuit. This will require troubleshooting by a repair specialist, unless you can obtain a diagram and do a little spy work with an oscilloscope
Nov 05, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung 27"
Hi, maybe just maybe something screwed in the yoke. Other than the vertical deflection coil, you may want to try to check the associated components. Sometimes they have diodes connected as a limiter/shunt. Again maybe... Pls post back, curious too. Good luck.
Apr 27, 2007 | Samsung TXJ2754 27" TV
Sylvania 6427TE 27" TV Logo
180 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
