Question about GE DBXR463GB Gas Dryer
Dryer wont heat up
Model DBXR463GD1WW wont heat, all ducts are clear and cool air is leaving the unit. Any suggestions?
  • sacheti Nov 08, 2008
    I have same problem. But how do I replace the igniter. Where is this located.
  • Anonymous Jan 14, 2009
    The burner comes on every couple of minutes but the flame only lasts for 15-20 seconds. The clothes aren't drying.
  • 1,543 Answers
The most likely cause is a burnt out igniter. (part #
WE4X739) The igniter is a pencil shaped curly wire thing with a two pin disconnect located between the gas valve outlet and the burner box.
Posted on Aug 28, 2008
Frigidaire GLGQ642A Gas Dryer Problem - runs warm - cycles hot then cool
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Aug 11, 2008 | Frigidaire GLGQ642A Gas Dryer
No heat or air blowing inside unit
Are you sure you dont have a clogged Dryer Vnet?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Feb 09, 2014 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Ge Profile Electric dryer model DPSE810EG5WT The
Hi.
If the fan does not work at all,then the fan motor must be replaced. The fan is tested jumping its contacts to energize it directly.
More commonly the problem is clogged air ducts. Check lint filter and check ducts for blockage. Ensure that the air duct is well in place.
Jun 27, 2010 | Dryers
BURNER WILL NOT LITE AFTER THE INITIAL HEAT CYCLE,THE IGNITER COMES ON BUT NO GAS COMES THRU. ALL IHEAR IS A CHATTERING SOUND COMING FROM THE BURNER AREA. THIS IS A KENMORE GAS DRYER, SER.# LGR762OLGO
if the igniter glows do u see the flame, and then shuts off,
you can have a copule things going there
one you might a block exhaust vent,full of lint, even when it seems like the duct is clear all the way to the outside, you might have some lint inside the unit, try cleaning it by removing the back panel screews, the air duct, and then remove i thinks is 4 or 5 screws from the air shoot, open it an clean the inside, what sometimes happens is that the blockage is there on the duct, the heat is created but won't exit the unit, and it back flows, rising the temp, and the dryer won't turn back on till it cools off
if you clean the ducts an you still have the problem, then i would look at 2 thigs first the coils replace em
an then the gas valve....
goosd luck post some feed back thanks!
Feb 01, 2010 | Kenmore Dryers
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
I believe my heating element is about to go south on me. Actually, it is gradually not getting the clothes dry, even tiny loads. I need a schmematic or directions of just how to replace it myself and what...
Are you sure the heating element is going bad? You may simply need to clean your dryer exhaust ventilation ducting. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you haven't cleaned your vent ducting and/or dryer interior any time recently, now may be a good time to do so. A simple test you can try to determine of you have a dryer vent problem or a heating circuit problem is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. If the air leaving the dryer is forceful and warm (about 140 degrees), then the problem is not INSIDE the dryer. The problem is with the exhaust ventilation AFTER the dryer. You will need to inspect the entire length of the vent hose for kinks or clogs. If the air leaving the dryer is weak and cool, you either have a clog in the air blower assembly inside the dryer or you have a definite heating circuit issue.
I'm not trying to second guess your diagnosis, just trying to give you some things to consider that may save you from needing to purchase parts. If you have already attempted these steps and still want instructions on how to replace the element, post back with your complete model number so I can give you accurate advice. All Whirlpool dryers are not assembled alike. I hope you find this helpful.
Jun 11, 2009 | Dryers
Water is running out from beneath the dryer
If you have water leaking from a dryer, then you have a clog in your exhaust ventilation ducting somewhere. If the lint is allowed to accumulate to the point of clogging, the warm moist air condensates inside the dryer and ventilation causing more lint to accumulate due to the moisture. This condition will only get worse and needs to be remedied as soon as possible. Water inside a dryer is a hazard due to the electric components located in the bottom of the unit. This is where your drive motor and heating circuits are located.
I would strongly recommend you try this quick test. Unplug the unit and remove the exhaust vent hose from the back of the dryer and try drying a load as you normally would. If the air flow leaving the exhaust is forceful and warm, then the problem isn't inside the dryer. The problem is with the vent ducting AFTER the dryer. You will need to inspect for kinks or clogs in the hose from the point where it leaves the dryer, all the way to where it exits your home. If the ducting hasn't been cleaned in a while, now might be a good time to do so. Leaving a dryer in a clogged state will eventually cause it to overheat to the point of failure. Not to mention, this creates a fire hazard and a habitat for rodents. Mice love dryer lint.
If the air flow leaving the dryer is weak and cool, you may have an internal clog inside the dryer. Inspect the air blower assembly for clogs or obstructions and clean as necessary. Cleaning the lint screens on dryers isn't always enough. Some lint does get past the screen and can accumulate over time. Periodic inspection and cleaning is recommended. I check mine about every three months.
Always remember to unplug the dryer before servicing the inside of the unit. If you have questions along the way, please let me know. I hope this helps you.
Jun 11, 2009 | Kenmore 62602 Electric Dryer
Cold air coming from the intake of the central a/c unit. The unit is switched off and it is winter, so why would cold air come from the intake
Thanks for your question,
Just a couple of questions first, is your ducting insulated ? is there a fresh air intake on your system ? if either of these is the case, the first would be that you need to have your duct insulated, it is good practice to have them insulated as it will save you money down the road as to not have as much heat loss or cold air from the duct escaping into the home, second if you have a fresh air intake, alot of times that is where fresh outside air would be coming in from, there should be a damper on the venting, if there isn't I would suggest having one installed, normally it is installed on the return side of your ducting. Hope that was helpful, please leave some feed back as to how we did, thanks again,
mr.grzz
Jan 23, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Clothes are not getting dried.
Check your dryer ducting.  If you have not cleaned your dryer ducting recently, it may be time to do so.  In order for a dryer to work correctly, it needs proper air flow.  A lot of people don't realize that just seeing the heating element glowing and the air blower fan running isn't enough to get your clothes dry.  If the dryer does not have a proper exhaust the air has no where to go.  All that air that is normally exhausted out of the dryer vent carries all the moisture from your clothes with it.  If the exhaust is clogged, all that moisture stays in the dryer and the dryer works harder to try to heat.  Your clothes stay wet and, eventually, your thermal cut-out and/or heating element will blow.  You could also have a clog somewhere inside the air baffle in the dryer.  This is where the exhaust fan is.  Lint can get trapped in this area clog up your dryer.  Here's a simple test you can perform:
1. Remove the exhaust ducting from the back of the dryer and dry one load in this manner, letting the dryer exhaust freely into your laundry room or garage.  Feel the air leaving the exhaust port on the back of the dryer.  The air should eventually heat up and be rather forceful.  If your clothes dry faster, then you know you have a clog somewhere in the ducting.  You will need to trace it all the way to where it leaves your home at the exhaust vent outside.  If it is run in a crawl space, make sure it is suspened from the rafters and not on the ground.  Leaving it on the ground makes it susceptable to rodents wanting to chew through to get inside your dryer.  Dryers provide a great source of warmth and bedding material (lint) and mice love them.  Also ensure thre are no sags in the line that will create areas for lint to collect.  If you find that your clothes are drying better, take care of the problem immediately.  Running a dryer for extended periods of time exhausting in your home can add unwanted humidity, dust and potential mildew.
2.  If your dryer still is not drying sufficiently, or you have very weak air flow coming out of the rear exhaust port.  You will need to remove the air baffle housing and check for clogs.  I experienced a home where a dryer would not heat, but the ducting was clear all the way to the exterior vent.  The heating element was also heating properly.  When I removed the ducting, however, there was barely any air coming out of the dryer.  When I inspected the air baffle housing I found a mouse nest as big as a shoe box and compacted to the point that I had to disassemble the unit to get it out.  You will find that MOST insufficient drying problems are directly related to the cleanliness of your dryer interior and your dryer ducting.  Not to mention, the potential for house fires if you do not maintain a dryer properly.  I have also found situations where lint became so backed up in a dryer that there was evidence of multiple fires inside the dryer.  Take the time to double check your dryer venting and replace those old plastic worn out vent hoses with new semi-rigid metal hoses.  They resist crimping and crushing and will not clog as easily.
NOTE: It is normal for the heating element to cycle on and off.  This is actually a symptom of a "healthy drying cycle".
I hope this information is helpful to you.  If you find no obvious signs of clogs or obstructions, let me know.  You may have something else causing your problem.
Oct 31, 2007 | Dryers
GE DBXR463GB Gas Dryer Logo
212 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
