Question about Sylvania 6427TE 27" TV
Elongated picture It appears that my picture has grown vertically and folded back on itself at the top of the screen. I would think that a simple vertical adjustment would solve the problem, but there is nowhere to do this procedure on either the remote or the tv itself.
  • 1 more comment
  • 3Val Sep 12, 2008
    Same tv, same problem, but it now has the thin line in center. How can I repair this myself? Can I get parts at Radio shack?
  • corrykuipers Dec 29, 2008
    I bought 2 of these tv's and they both do the same thing. the picture is elongated at the top and bottom so I miss part of the picture. I have tried to adjust it with the controls on the inside of the tv but it only helps a little. the sides of the tv picture seem to be pin cusioning also.
  • corrykuipers May 11, 2010
    I would really appreciate you checking for a solution.
  • 4,234 Answers
There is a bad capacitor in the vertical circuit. If you feel comfortable working inside a set and can solder, update this and I'll try to get the specifics for you.
Dan
Posted on Aug 29, 2008
HORAZONTAL TRACE OVERLAP AT TOP OF SCREEN. MY TOSHIBA 32D46 TV HAS DEVELOPED WHAT LOOKS LIKE A FOLD OVER OF THE TRACE AT THE TOP OF THE SCREEN, ABOUT 2 INCHES. CAN THIS BE ADJUSTED OUT BY ADJUSTING THE...
Usually that is caused by a part failure. The vertical deflection ckt is most likely the roblem. Sometimes it's just a cap usually a 100mf right next to the vertical ic chip. Or it can be the ic itself. Unfortunately you can't adjust it out.
Feb 23, 2010 | Toshiba 32D46 32" TV
I HAVE A JVC AV27D302: THE PICTURE IS FOLDED OVER
For how many years this TV with you? Most tv now a days after few years of using vertical IC solder started to dry(dry solder) you can try to re-solder or you may check also two capacitors (100uF/35V) for most JVC model has this symptom with this parts changes its electrical characteristics. If still problem persist replace vertical IC. Hope his helps, Good Luck
Feb 14, 2010 | JVC AV27F476 27" TV
Top of creeen rolls over and back down from the top about 3"
There is a capacitor in the vertical circuit that has significantly changed value causing this. If you are familiar with these units, look for a capacitor with the value of around 100ufd that is part of the vertical circuit and change it. That should resolve it. If you bring this to a shop, expect a parts cost up to $10.
Dan
Mar 17, 2009 | JVC AV-27920 27" TV
Elongated picture on Sylvania 27" Model # SRT2232S
there is a vertical adjustment on the picture tube it's the yoke as it's called but you can adjust it so much..but it does sound like the tube is on it's way out
Aug 28, 2008 | Sylvania 6427TE 27" TV
My tv has this lines that bend over the front top of the screen and when an object moves through the lines the image appers from the the top of where the line begins...and the tv goes black every once and...
This sounds like a vertical deflection fault. There are some components that are failing in the vertical deflection area that are starting to fail. It is very common in many of the sets that there are electrolytic capacitors in the vertical amp section that are gong out of specifications.
When you have at the top or the bottom of the screen where the vertical axis is compressed, and the picture in the compressed area looks like it is inverted and going over on itself, this is called "vertical fold-over".
An experienced TV service technician should be able to service this for you.
Jerry G.
Apr 18, 2008 | Televison & Video
Vertical stretchon pictures
This is from what you describe - more the computer dispkay than a camera proble.
How do other images look[not the camera] on the screen?
or the deck top. -Check out this first them come back to the camera images.
Nov 15, 2007 | Canon PowerShot S3 IS Digital Camera
Tv problem
Bad capacitor in vertical output IC circuit + check power supply
Last, replace IC.......................T.
Nov 09, 2007 | Philips 27PT6441 27" TV
Sony 27" picture quality
You probably have a leaky or open electrolytic capacitor in the vertical circuit. This will require troubleshooting by a repair specialist, unless you can obtain a diagram and do a little spy work with an oscilloscope
Nov 05, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Horizontal line in my TV.
"Guest" obviously has no idea what he is talking about. There is no such thing as "frame section" and if the vertical IC, ramp generator or vertical hold circuits were bad, you would have no vertical at all. If you mean that there are thin white lines at the top 3 inches of the picture, and the top of the picture seems folded back on itself, it means that the pump-up capacitor is going bad in the vertical output circuit. This is a very easy thing to correct but should be done by a qualified tech.
Sep 01, 2007 | Televison & Video
Sylvania 6427TE 27" TV Logo
89 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
