Question about Cameras
I just purchased a new smsung model S630 and i never received a manual for it. I have been able to do some things but now the camera says MEMORY FULL and i do not know what to do. I have already down loaded the 9 pictures i took to the computer but it still comes up MEMORY FULL.
    Master:
    Sergeant:
  • 398 Answers
When you "Download" to the computer, you actually copy them to the computer, they will still be in the memory, check the camera menu for a delete process, and delete them and you will be good to go.
Posted on Aug 29, 2008
Will a 4gb sd memory card work on a s630?
Yes and no. According to the manual the S630 will work with SD cards up to 2GB in size and with 4GB SDHC cards. If the cards at the store are actually SDHC cards (most likely since 4GB SD cards are very rare) then they should work fine.
Jul 21, 2012 | Samsung Digimax S630 Digital Camera
My Samsung S630 won't connect to the computer so that I can download photos taken. Any clues as to the problem?
Problem with the actual cable, the USB port being used on the computer, or the actual connection on the camera itself. The quick fix would be to take the memory card out of the camera and purchase a cheap memory card reader that you can put the card into and the PC will read that fine. From there you can copy the images over and even delete them. It reads like a jump drive.
Prices start about $10.
Feb 28, 2011 | Samsung Digimax S630 Digital Camera
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
When i try to take a pic screen reads memory full but i have no images
Have you tried to format the memory card in the camera?
Try that, follow the directions in the manual on formatting the card. That should work.
Jul 13, 2009 | Samsung Digimax S630 Digital Camera
Kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
Jan 18, 2009 | Kodak EasyShare C330 Digital Camera
I just purchased a samsung digital camera model S630 and the MEMORY FULL is flashing on the screen but I have down loaded on to te computer. Whats up. Im very new to all this. Thank you,Jim Hadwen
Unless you checked the box to delete your pictures from the camera chip, they will stay on it. You can also delete them with your camera menu.
Aug 28, 2008 | Samsung Cameras
Memory Full but no pics
hi moziz;
you may try resetting it to factory settings, try to search for it in the camera menu. as for your second question; some cameras have internal memory,thus doesn't need memory card while others don't have internal memory and needs memory card.
ill wait for your reply. :)
Jun 04, 2008 | Samsung Digimax S630 Digital Camera
Memory Card
If you transfer the photos to your computer from the camera, you should be able to save to another memory card. I can't say whether or not the photos on the new memory card will show up on your camera since there may be certain requirements to display on camera screen.
Plug your camera into the computer USB or insert old memory card. A box should pop up giving you the option to view files. Copy and Paste (or Drag) selected photos to a specified folder on your computer (Like My Pictures in My Documents). Insert new memory card. Copy and Paste (or Drag) selected photos to the drive for your memory card.
May 06, 2008 | Samsung Digimax S630 Digital Camera
Vivitar vivicam 3785 new memory card
Might be that the card is too large/small for camera to recognize, or it is a newer type of memory. Look up the specs for camera and compare to stats of memory card.
Nov 13, 2017 | Vivitar ViviCam 3785 Digital Camera
Power supply
You can download the manual from the link below: http://downloadcenter.samsung.com/content/UM/200703/20070330162556328_DigimaxS500_S600_ENG.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
