Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Check enging light 2005 harley 883 sportster
Hello i have the aboved mentioned vehicle. has 10000 miles on it. the check engine light tends to come on for 5-10 sec then goes out at freeway speeds. can speed up or slow down sometimes and it will go out. then will be about 5-7 miles it will come on again. very random. Is there a way to pull the codes and see what code is being set. If not any comon problems that fit this description? thanks foryou help.
  • Anonymous Oct 31, 2008
    I have same problem, i had vance& hines pipes put on 2003 heritage softail. rode several times. went on a 80 mile trip & engine light came on. bike is running fine, no miss. crankes fine. im worried the pipes may have had an affect on motor.
    Genius:
  • 2,028 Answers
This could be the air filter, check and clean it, then go ride to see if the cleaning cured it. Also check the breather tube for the blow by from the heads where it dumps into the air filter assembly, if something is partially plugging them it could cause this. It could also be the fuel mixture isn't quite right, and needs adjusted. The only way to pull the codes is to find a shop with a code reader. Most likely it's going to have to be an HD dealer, but you can check with some of the smaller shops locally. I'm really getting irritated with HD for going to the electronic era and making their bikes as hard to work on as some of the cars now days. Their not simple anymore, and what used to be a simple diagnostics is turning out to be a major event. This is why I like my 95 model, old, carbed, simple!!! Anyway, Ive ranted enough, hope this helps in solving the problem. If you need anything else, just ask.
Posted on Aug 28, 2008
I lost all my lights on 2001 Harley Davidson 883 sportster
check all ground wires, start at battery, you lost ground connection gradually.
Aug 09, 2014 | 2001 Harley Davidson XL Sportster 883
2005 XL1200C check engine light
Read your service manual on how to retrieve your error codes. Then look up what those error codes mean. If the engine seems to run fine now, try clearing the codes and see if they show up again. If they do look into what the code is warning you about and check that item.
Aug 24, 2012 | 2004 Harley Davidson XL 1200 C Sportster...
My speedo has stopped moving on my xlh 883 sportster, needle doesn't move and miles not changing, lights on and it only happened today.
Check for the speed sensor above the gear box Remove the allen screw on the speed sensor and clean the speed sensor with a rag, as there surely filing on it... Hope this help.
May 09, 2011 | 2001 Harley Davidson XLH Sportster 883...
Check engine light goes on and off on my 2006 harley sportster 883 custom
Hi Usmc7caron, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Davidson Sportster error codes and how to access them
Jul 14, 2010 | 2006 Harley Davidson XL 883C Sportster...
2005 Harley sportster 883, plugs are good , wires are new, no spark when cranked up
is 12 volts getting to the coil,.check the ignition module under the cover,all the wires tight,check wire to the points,
Jun 29, 2010 | 1993 Harley Davidson XLH Sportster 883
2006 883 801 miles check engine light, engine sputters,
You are going to have to pull the trouble codes out of the computer. If you can't do it yourself, a dealer can. This will give you a starting point to diagnose the problem.
Nov 26, 2009 | 2006 Harley Davidson XL 883 Sportster
Lands Phones Logo
246 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
