Question about Andis Edjer 15515 Beard Trimmer
Not Trimming Properly
I put the blades together after i cleaned it...but the blades are not working properly .....in other words i cannot trim anymore....i tried different ways but it is still not trimming. Is there a way to put the blades in the right position or is there any repair centers in Montgomery Village, MD that can help me out. Thank You
  • 62 Answers
For the replacement of blades please visit the Andis website at www.andis.com. Choose USA, then service, then use and care. Once you are at the use and care section find your model and click on it to bring up the instruction manual.
If you are still have problems there are two service stations in Maryland as listed below. If neither of these are close to you you can send the unit into Andis for repair.
Water's Appliance Service
216 E Diamond Ave
Gaithersburg MD 20877
301-258-7500
800-225-5009
Hemps
13407 Graceham Rd.
Thurmont MD 21788
301-898-9916
Fax 301-271-3610
If you should have any further questions please do not hesitate to contact the Andis customer service department at 1-800-558-9441.
Thank you for choosing Andis.
Posted on Nov 17, 2008
Why isn't it trimming the fabric off as it was before?
The blades may not be hitting where they should, ie a gap between the blades allowing the fabric to slip instead of cut. NOTE: according to most serger manuals, one blade can be changed/altered by the user, but the other blade should be done by a technician because it involves timing.
Jan 30, 2016 | Sewing Machines
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
I am looking for pictures of trees that is been cut of
Search for website on logging, or tree trimming business
For example you live in Seattle... then search: tree trimming seattle
Also open google... select images at top of page... and do image search for: cut trees etc
Aug 26, 2014 | Woods Hardware & Accessories
How do you convert the Echo grass trimmer model SRM-22ges to the brush cutting option?
There is a hole just above the grass trimming head that you can slip a screw driver into. Turn the head so that the inner and outer holes align where you can put a screw driver or other hard steel object in. Put it in there and then turn the head counter clock wise until it comes off, it may take a little effort to get it to move, but you should be able to do this with your hands. Once you get the trimmer head off, put the blade on and hopefully you still have the nut and washer accessories to hold the blade in place. You will need to place your screw driver back in the alignment hole to hold the head from spinning while you tighten the blade nut back down. Make sure it is tight, you don't want that blade coming off at ~10,000 rpm!
Aug 23, 2014 | Echo Garden
Qualcast GGT350A1
Hi. It all depends on the Lawn trimmer. What brand is it? You can go back where you purchased the Lawn trimmer and ask them for an attachment blade to use for trimming hedges (did you mean hedges as in edges?). If they have blades specifically for your trimmer then you can do best if you have it attached to the trimmer by them experts. Otherwise if you do it yourself and it's not attached to the trimmer properly, and it comes off while spinning at high speed, you'd better run for your dear life, man! Hedge blades, like the one I have on my trimmer, are subjected to strenuous work and can come lose if not attached properly. The main part is that you treat hedge blades with care when doing the changes yourself. I am not saying that the blade which is similar to a saw blade, could come lose and separate itself from the shaft and fly towards you, but it's better to be safe than sorry. Poorly attached blades do come lose and fly like a flying saucer spinning and whirling in all direction like a yo-yo. Cheers
Michael
Jun 16, 2014 | Garden
Trimming with #10 blade seems to work ok but #7 blade will grab the hair and will not cut clean. I've purchase another new #7 blade to see if the blade is the problem but the same result. Any ideas? Thanks...
I have the same clipper and have found that if you comb,wash and dry the hair thoroughly first, it works alot better! Also putting a drop or two of the oil on the outer edges of the clipper. (did you get a dvd with it?)
Apr 19, 2010 | Andis Advanced 21490 MBG2 Hair Trimmer
Blade does not move when turned on
Try spraying the blade assembly with a good rust remover like PB Blaster or even WD 40. Might be something is rusted and won't let blades move. When you are done trimming reapply some oil to displace any water that comes out of whatever you are trimming.
Good luck
roundo4
Aug 09, 2009 | Black & Decker Hedge Trimmer
My clippers are running and the blades are moving but they are not cutting the hair
make sure it is cleaned and before putting it back together put a drop of clean oil between the blades. Also make sure it it adjusted properly.
Aug 04, 2009 | Andis 01690 Hair Trimmer
I just purchased the Conair GMT182x, and have no idea how to change to the styling blade for trimming my goatee.
Place your index finger, middle finger, and ring finger on top of the blade, and place the thumb under the blade and push the blade up (using the thumb). This will remove the blade
Select the blade you want to use
Put the new blade in back, then push down on the front of the blade, you should hear a snap, and the new blade will be in place.
Apr 24, 2009 | Conair Health & Beauty
I have tried everything and it still doesnt trim what am idoing w
if it is pulling instead of trimming, you may need to oil your blades (they're sticking). there should have been a tube of oil in your package. run just a small amount of oil along blades and turn on to let the oil get worked in. do this regularly but don't over oil them, it gets messy.
Dec 12, 2008 | Conair MN250CS Hair Trimmer
Andis Edjer 15515 Beard Trimmer Logo
224 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
