That's a bargain if it works. Apparently the date is hidden in the last three digits of the serial number, so February 1998 seems likely. The only sure way is to contact Hobart themselves. They have a great service department. I have used many Hobart mixers in my catering career.
I found this;
As the previous poster mentions, you can't decipher Hobart serial or ML numbers. I have about 30 pieces of Hobart equipment ranging from mixers to slicers to reach-ins to dishwashers and I couldn't make heads or tails of the numbers. Finally, I got hold of someone at Hobart who I emailed all the model numbers, serial numbers and ML numbers to and they emailed me back the month and year of manufacture. Even after I got the information, I still couldn't figure out where in the serial and ML numbers the manufacture dates were buried.
There are several possible causes:1. The blades of the beater/s may be distorted (bent) 2. The beaters are in the wrong way round 3. The bottom tray is not seated down properly - there may be something in the central hole 4. The bowl may be damaged
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
Hi. If the motor does not turn, the problem is electrical. Trace and test the electrical circuitry with the mixer unplugged. Start with the electrical plug and work your way through to the motor and switch connections. An electric motor technician should be called in if you are not familiar with electrical troubleshooting techniques. Good luck!.
If this solution has assisted you, please rate it. ricardok45
There is a website called onesharpstore.com that specializes in food processing appliance parts. I saw the hobart model 1812 listed there just today (03/07/09). They even have a number you can call direct. 772-770-4383.
