Question about GE GSS20IEP Side by Side Refrigerator
Not cooling or freezing
Model #GSL25JFPA BS
Refrigerator is not cooling and freezer is not freezing. Also ice maker not making ice. Water does come from the dispenser and I do hear the compressor coming on.
  • 5 more comments
  • Anonymous Sep 02, 2008
    Sides and divider between freezer and fridge are too hot to touch. No ice being made. Freezer seems cold but not cold enough. Fridge not cold at all. Water in door works OK but comes out hot when first used.
    Help!
    Model Electolux/Frigidaire GLRS237ZA
  • Anonymous Sep 07, 2008
    I have same problem
  • businessfish Sep 20, 2008
    Ice maker does not make ice and the water over flows.
    Compressor runs and cooling fan too... Much dust removed
    from condenser but did not help... Refrig side cold, but
    freezer will not freeze... MUCH frozen condensation on
    back wall below ice maker... Like a 1/2 inch thick...
  • Anonymous Dec 13, 2008
    I have the same problem.
  • franciscoton Dec 22, 2008
    the temperature will all of a sudden start to rise, and then it will start cooling again. This happens in both the freezer and the refrigerator, I have the Artica model sxs 26
  • GEprob Dec 23, 2008
    The refrigeration stopped functioning last night.  I do have power to the unit and just verified that there is no voltage to the capacitor.  In addition I have measured the capacitance of the capacitor as being correct.  I have also verified that the overload, relay and compressor motor are all functional.  The evaporator fan ran when the when the power was returned, but the condenser fan dosen't for a period of time and then stopped.
    Any ideas?
  • rfenwick Feb 24, 2009
    The upper portions of my freezer and fridge both warm up, causing thawing of the ice in icemaker, then it will work again. I have had this problem at least 4 times. Now my icemaker wont work.
My refrigerator is getting warmer and warmer, but my freezer is still cold. Inside the refrigerator near the fan at the top a small amount of ice was noted and A LOT of condensation on the underside of the shelves. this is the big problem. my ice despensor hasnt worked in years. well off and on. mostly off. and the water pressure out of the dispensor is dreadfully slow. any suggestions?
Posted on Aug 03, 2009
I replaced the defrost heater and the termostat. But water and ice still forms in the back, so I turned off the ice maker and refrigerator and freezer work. It seems that something is broken from the ice maker device, so I may need to replace something else.
Posted on Sep 19, 2008
  • 1,543 Answers
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Posted on Aug 28, 2008
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Jcb 2059 Jen air fridge not cooling freezer o.k.
Its a defrost issue.The freezer works,then cooling starts and then its time to defrost.But in defrost the unit is not working.It can be faulty defrost assembly parts.Or the problem is with defrost timer at the lower back side of refrigerator.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
Cannot adjust contol to freezer and no sound to the compreeor
May be faulty compressor or issue with compressor control capacitor.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Zanussi Z57 / 3 Bottom Freezer...
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
These will help.
Thanks,.
Freezer fan not running
It can be faulty fan motor or blown compressor capacitor.
These will help.
Thanks,.
Refrigerator model rb215labp The fridge freezes, fridge drawers freeze, top shelf is too warm
Its not working.Two possibilities,either faulty compressor or issue with defrost assembly.Defrost cycle not working.
repairclinic.com
partsselect.com
These will help.
Thanks,.
The water in the in-door dispenser is coming out hot
If this freezer is like most, the water going to the dispenser is looped around many times in the refrigerator section near the back. Make sure that this is still true. It must have a lot of water cable in the refrigerator section so that the water has time to cool down before it goes out the dispensor. If for some reason the water tube is touching either the compressor motor or another hot part of the external refrigerator it could cause it to be to hot to cool down in time during its travel through the refrigerator as well as it will start to warm up the refrigerator section as well.
Also, I am sure you have tested, but make sure that you are plugged into the cold water supply and not the hot water supply. Check the water at the connector and see what the temp is at that point before it enters the refrigerator.
My guess is that the coil of water tubing that is usually in the back of the refrigerator section has been either lessend in length or the water entering the refrigerator is too hot to be cooled down in time before it reaches the dispenser.
hth
Feb 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
797 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
