Question about Apple M9034LL/A Keyboard
Malfunctioning new aluminum keyboard x 2!
My new aluminum Apple Keyboard ["Apple Keyboard Kit" purchased from Amazon.com, LLC] started to malfunction three weeks after I received it.
I really like the keyboard, so I replaced it with same model. When the new keyboard came it gave no pretence of functioning like it should. It malfunctioned in the same way right from the get-go!: deleting forward-only, no Return key function, insane Arrows function, et cetera... [It malfunctions slightly different in different applications.]
Is it possible the first new aluminum keyboard started malfunctioning after three weeks because my iMac Software Updater came up with an update I agreed to but which caused a problem for the first new keyboard and consequently for the second new keyboard?
In researching this problem, I found suggestions to run the Software Updater. It came up with no keyboard software updates. The next suggestion was to download the latest upgrade manually [Keyboard Software Update 1.2] and install it. I did this. Because nothing changed with the keyboard after the installation, I did a search for Keyboard Software Update 1.2 but only its .dmg on the desktop was found. I then installed it again, same non-results... I don’t think it really installed.
Now what?!?
A really, really non-tech person!
Carole
[iMac G4, Power PC/not Intel, Mac OS 10.4.11]
  • CaroleA11 Aug 29, 2008
    Thank you for your prompt response, Ekse! I will certainly try your
    solution but because of a physical disability that requires use of a
    power wheelchair, I can not do this myself. It may take at least until
    Monday for one of my caregivers to take the keyboard to another
    computer. [The first new keyboard has already been returned.] May I
    take this amount of time to get back to you? Thank you, again - Carole
  • Apple Master
  • 6,487 Answers
The malfunction of the keyboard has nothing to do with teh software, even you dont update the software of it the keyboard should still work fine and this can only be another set of bad keyboards , I realy suggest to you to have this second keyboard relace again, because for the first place it should work fine as soon as you use it no software upadate can cause this problem..
Hope that helps.........
Posted on Aug 28, 2008
  • Apple Master
  • 13,433 Answers
Are you sure its a issue with the keyboard, I would suggest trying these two keyboards on another system to see if they really are at fault.
Thanks,
Ekse
How do I fnd a used keyboard for
try Amazon or ebay here is one on Amazon not sure it is for your exact model. http://www.amazon.com/Macbook-Pro-keyboard-assembly-A1278/dp/B0065UZMJ8
Aug 22, 2014 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
I CANT USE MY KEYBOARD ON IBM X40 THINK PAD TYPE 2371 03
Your keyboard may be malfunctioning. In this case you will need to locate a replacement keyboard for your system and replace the old one.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=IBM+X40+keyboard&x=0&y=0 will take you to a location with multiple options for replacement.
To remove your old keyboard the reverse side of your laptop will have screws that are marked K or with a keyboard icon. Remove these screws then you should be able to remove the keyboard from the framing. There is a cable connected that you will have to disconnect. Pay attention to where this is and don't just yank the cable as it will have a locking mechanism on it that you do not want to break.
The new cable will have to slide into that same spot and be locked in place. You will then put the new keyboard in place and screw it in. This should resolve your keyboard issue.
Nov 25, 2011 | IBM Computers & Internet
Hnjhjhjh
Your keyboard is malfunctioning. Buy a replacement.
Turn the computer off.
Disconnect the old keyboard.
Connect the new keyboard.
Start your computer.
Oct 27, 2010 | Computers & Internet
My apple aluminum keyboard not working with Macbook Air
try to connect your keyboard to the mac air while mac book is connected to internet (by wifi) then update your programs (apple menu - update).
Dec 22, 2009 | Apple Computers & Internet
IMac Aluminum Keyboard not all keys working
Hi Bilbo,
Do you know if the keyboard has come into contact with any liquid? That can cause shorts in some of the connectors. Regardless of reason for failure, these keyboards, when they start failing, do not have repair options. Purchasing a new or used one will be the only option.
Keep in mind that these wired keyboards are also no longer made by Apple, but you can find them online at various sites. You can also use different Apple-friendly brands like Logitech if you'd prefer to stay with a wired keyboard.
Sep 30, 2017 | Apple M9034LL/A Keyboard
I fitted a plug and play usb wireless keyboard and mouse now my laptop keyboard gives incorrect stokes ie. m=0 k=2 '=` can anyone advise please
are those keys placed on corect spot?, try to use it on a desktop and if still malfunctioning then somethings wrong with ur usb keyboard .better replace or buy new usb keyboard if problems still occur
May 30, 2008 | Computers & Internet
these keyboards do not service simply, sorry but at least any usb keyboard will work
Apr 29, 2008 | Apple M9034LL/A Keyboard
Mac and Vista
Operating System doesn't deal anything on your problem. The problem depends on the brand of you computers or the type of keyboard you are using.
The GCS632U is designed to work with standard USB keyboard and mouse only. And wireless and gaming keyboards and mice are not guaranteed to work correctly with this KVM switch. If any one of you is using the new Mac Aluminum keyboard, this keyboard will not work with the older version of the GCS632U. But IOGEAR releases a new batch of GCS632U that would work with the Apple Aluminum keyboard.
If you have an Apple Aluminum keyboard that does not work with the GCS632U, you may contact the IOGEAR Tech support and they will process a Return Merchandize Authorization (RMA) if your device is still under the warranty period.
To resolve your keyboard issue, try to power cycle the KVM switch by disconnecting it from the computers, disconnect also the keyboard and mouse from the KVM switch. Leave it disconnected for two minutes. After two minutes, reconnect everything and reboot the computers.
Oct 20, 2007 | IOGear GCS632U 2-port KVM Switch
Apple M9034LL/A Keyboard Logo
242 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
