Question about Acer Aspire SA80 (ASA80UC4603) PC Desktop
AS problem The computer's fan will go on but the computer won't start up.
    Scholar:
  • 113 Answers
Any bleeps, or lights at all?
Plug power cable out from the back of the PC, leave out for a few minutes and retry.
If there is a modem in the PC remove it and retry.
Change the Power supply if possible, see can you get a friendly PC hack to loan you one for a test :-)
If still no "post" activity there is a good chance that your problem is either motherboard or CPU related. let me know how you get on with first suggestions
Posted on Aug 29, 2008
Computer won't start
YOU HAVE PROBERLY A BAD PSU.TRY WITH A OTHER PSU IF POSSIBLE.
Jul 05, 2013 | Computers & Internet
Won't start up little green light flashing on back
the green light flashing on the backside is your internetconnection.
about the computer wan't start i should check the PSU do the fan movs any light on the motherboard.if not is the electric cord firmly and tight in place.if the fans runs and lights on the motherboard.you got no picture proberly brooken videocard.
Apr 11, 2013 | Computers & Internet
COMPUTER WON'T START
See if power supply fan is running. If not....the power supply is bad. Also...see if there are any lights lit on the Motherboard. If not....the power supply is bad. You can pick one up on ebay pretty reasonable. Hope this helps.
Feb 02, 2013 | Dell Inspiron Computers & Internet
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer.
The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
May 27, 2012 | HP Pavilion g60-440US Notebook
Computer won't start up
Firstly check the power supply and all the cable are properly are plugged or not.
After check The SMPS FAN are working or not or cpu fan is working or not .
put out the ram and properly make it dust free. and after put is properly.
Apr 30, 2012 | Dell Dimension E521 PC Desktop
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
Desk top computer w/ SN: CNH4390C89, P/N PJ506AA, won't turn on. when it was working, fan was noisy most of the time
The computer fan may be clogged with dust or may have failed. The computer monitors the fan and if it is not working it will not let the computer start. It is a way for the pc to keep itself from overheating. Unplug the computer and open the cover and carefully try to vacuum or blow out all the dust. Then with the cover off try starting the computer and watch the fans and see which one is not turning, it may start if there was a lot off dust. If not the fan may need to be replaced.
Thanks for using FixYa.
Jun 20, 2011 | HP Compaq Presario SR1215CL (82916052980)...
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
Acer Aspire SA80 (ASA80UC4603) PC Desktop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
