Sony hxd 995 250gb,when set to record a program it, dosnt let me watch other channels does have twin tuner .Gordon
  • gpt1967 Aug 29, 2008
    all cables are fine,still does not allow to watch other channals when recording on other.
  • Anonymous Mar 25, 2014
    How to rename a recorded program. When push green button keyboard appears how to access also copy to USB
    Sergeant:
  • 241 Answers
HEY There are you using the HDMI hook up as your connections OR S-VIDEO OR RCA
YOUR TV SETTINGS HAVE TO BE SELECTED TO THIS
I USE TO HAVE A MODEL LIKE THIS DO YOU HAVE THE OPTION TO SET IT A TIME TO RECORD IF SO THAT COULD BE PART OF THE PROBLEM TOO
Posted on Aug 29, 2008
  • Jayson Brollini
    Jayson Brollini Aug 29, 2008
    I must be missing some info from you question because people are giving you adivse on repairing it?
  • Jayson Brollini
    IS THIS THE CORRECT MODEL NUMBER SORRY JUST WANT TO MAKE SURE BECAUSE THERE ARE A FEW DIFFERENT FACTORS THAT COULD CHANGE THE WAY I DIAGNOSE THE PROBLEM
    Master:
  • 638 Answers
The same problems is faced by many users.as it needs some perfect wiring system.that only a technician can do at your place.calling a tech is much advisable.it will save your lots of time.and let you know the perfect wiring connection for next time if such problem occurs.
thanks.
please do rate the solution.
    Master:
  • 521 Answers
You have to set the tv to the perfect mode.at present you have not done the proper settings so its happening.if you have manual go through it.or get a spare repair manual for your devica from the service center.or call the technician at your place to do that.it will not cost u much as he will not replace any part.because your device is proper only setting is improper.the setting is not available locally or i would have given you.but i had given you the options.please try.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 28, 2008
  • 6,487 Answers
There's a settings on the DVD player that you need to set so you can watch another channel while recording if you have the user manual check it from there..
Good luck..........
    Brigadier General:
  • 3,614 Answers
You first check the video connections
  • micromaster
    micromaster Aug 30, 2008
    check also the video output / input... it is better to have a separate output / input cable..
Want to know if u can tape one channel while watching another
I haven't met a DVR or a PVR that doesn't have twin tuners. This is the only way for digital reception to be acceptable for a lot of people used to watching one channel and recording another for the last few decades with analogue tv and the trusty VCR.
You should indeed be able to record one channel while you watch another or if the equipment is of premium quality it is possible you could record two programmes while watching something already recorded.
I hope this helps.
Mar 03, 2015 | Televison & Video
Why cant I change channels when recrding 2 progs?
Hello Anonymous,
You did not specify if you are using a DVR capable cable/satellite box, which I what I presume is the case.That DVR has two tuners in it - each tuner allowing you to watch and/or record two programs at one time and in any combination.If both of those tuners are used for recording then you cannot watch another "live" stream as there no available tuners to tune and display (or stream to the DVR hard drive for recording). You can only switch between the two recording programs.
As a side note, if your TV has a built-in tuner, you can split the cable and have one going to the DVR and the second run going to the TV set. You can then use the TV's built in tuner and watch what anything it can get. It won't get scrambled digital cable but will get analog and Clear QAM channels.
Feb 15, 2015 | Televison & Video
Hr836t how do i watch different channel to one recording
This unit has only one tuner, meaning you can only watch or record one thing at a time. Depending on your TV and how your equipment is installed, you may be able to split your antenna/ cable line and record on your DVD and use your TV tuner to watch another program.
Feb 02, 2014 | LG V271 DVD Player/VCR
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
SONY DVD RECORDER PROBLEMS
if it is only some programs, verify that your recording times are not overlapping and you are setting the timer for the correct times
Mar 17, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
Is it possible to record one show, while watching another ??
You need to put a cable splitter on the cable. One side goes to the TV. The other side goes to the recorder. The output of the recorder goes to one of the alternate inputs on the TV. Set the recorder for whatever channel you want to record using its internal tuner. Use the TV tuner to watch a show live. Later, set the TV input to whatever you connected the recorder output to and watch your recording. You will probably need to do this to see the recorder menu to set up the recording.
Mar 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
I have 10 year old tv Phillips model ts3258c101.Yesterday I purchased a digital video disk player & video cassette recorder. It will play a dvd. I now have found that I cannot record a video cassette...
Check if your disc player is a twin tuner model which will allow you to do what you want. It might just need configuring properly. Otherwise there are devices on sale that will allow you to achieve your goal. Good luck.
Sep 26, 2008 | Philips Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
