Question about Kyocera Oystr KX9 Cellular Phone
Kyocera oyster screen blank
Screen went blank, can still make and receive calls but cannot see display
I hope that when you say blank it means partially lit, with a kind of background, but no image.
This solution is not for an abused phone, as it does not seem to be mechanical, or due to a loose connection. It rather seems like a firmware failure. It will not make your phone usable, instead, it will enable you to retrieve your saved numbers. Once these cheap things start failing they become disposable.
Tried removing battery: No cigar. Tried opening it carefully (under 90 degrees) still no solution.
Here's what worked for me. Phone off, either by powering it down of by having removed the battery.
Get a toothpick, and with the phone CLOSED in the off position, pinch the power-on button and let the phone come on closed. It may not work the very first time, but you should be patient. Once it comes on, you can do just about anything with it until you power it down.
**Make sure you have charged your battery prior to this, since will be spending some time retrieving your numbers**
Good Luck!
Posted on Jan 03, 2009
That worked for me, thank you!!
Posted on Feb 13, 2009
    New Friend:
5-24-2013
Amazing ! Your sloution saved me.
I closed the OYSER and used a toothpick to turn it on.
I opened the lid and waited about a minute.
I accessed ALL of my contectg information and wrote it down.
Now I can enter it into my new phone,
THANKS for your help
Posted on May 25, 2013
Samsung Anycall screen won't light up
hi i have a problem on samsung shw m110s ..i cannot see any display but its working ..what shoul i do?
pls help
Jul 10, 2012 | Cell Phones
Sony p1i display screen problem or software problem??
sorry to say the display ic might have knocked off. if soft ware problem u wont might be able to make and receive calls either
Oct 29, 2008 | Sony Ericsson P1i
LCD screen went blank
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
Jul 28, 2008 | Nokia 3230
Blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
May 01, 2008 | Kyocera Oystr KX9 Cellular Phone
Screen
there's 3 problems u can have....replace the lcd., change flex... or faulty display ic .go to your nearest service center...hardware problems...
Apr 14, 2008 | LG KG800 Cellular Phone
Razr v3m
The Flex cable probably went bad on it and yes it can all of a sudden so this.
Mar 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Kyocera oyster
Shine a bright light on it and see if you can see and resemblance of the display on the screen. If you can see a display, the backlighting on the screen is broken - if you can't see a display, it's likely the screen is broken or the display controller is broken. Backlight would be the cheapest fix, usually. Also, you should be able to transfer your phone numbers over to a new phone by using the same SIM card so long as the phone numbers were stored on the SIM card - the only way to find out is to put it in another phone and check out the address book.
Sep 07, 2007 | Kyocera Oystr KX9 Cellular Phone
Screen is blank
you need to take the phone and have the lcd replaced.
Aug 16, 2006 | Motorola Mobility A630
Kyocera Oystr KX9 Cellular Phone Logo
1,707 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
