Question about Sharp Televison & Video
I have a common power on and off problem with my Sharp Aquos lcd37", couls you tell me where I can buy the repair kits p/n : PSPKIT663WHZZ ? Thanks Kevin
    Master:
  • 521 Answers
Sharp aquos 46 in
Check its fuse at the power supply board. If found burned, make sure that there is shorted component/s. Try to repair it. If the repair cost exceed than the cost of a new one, replace it as card basis. It will be more better than try to repair these boards.
Contact the authorised service center for Sharp, to buy a new one.
Jun 07, 2012 | Sharp AQUOS Blu-ray Disc Player
My Sharp Aquos TV will not turn on...just a green ligth flashing...something to do with power...how can i fix it?
The most common issue on these is the power supply boards. Bad capacitors on these boards are the issue and there are repair kits available if yur qualified for the repair other wise you can get new boards and swap them out. This is the most common issue in the business right now. Sharp sets are a little different in ther design on the power supplies but parts can be had and repairs can be made. You will need to balance the price for the repair vs a new set. Just Google TV power supply repair kits for Sharp Aquos and you will find repair kits and information on the power supplies.
If this was helpful a vote on the thumbs up would be greatly appreciated for the free advice.
Aug 22, 2011 | Sharp AQUOS LC-42D43U 42" HDTV LCD TV
Sharp 32" aquos LCD tv, will not power up with remote or switch on set, has power (120v) to end of cord where plugs into back of tv
This is usually some sort of power supply shut down problem the TV has detected a major fault, and has shut down the power supply to avoid a fire or explosion.. you need to get this unit serviced by a reputable repairer also always ask for a 'Quote: so you know weather to repair or replace.
Mar 21, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Aquos won't turn on. When pressing Power, it
Your power board ic converter it dead.
You know a little about electronic go to internet
buy the board repair it yourself or big screen tv repair people cost U about $575.
Aug 05, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I am thinking about buying a used 65 sharp
I wouldn't recommend buying it unless it came with some type of warranty.
The most common thing you would be looking at for repairs if something goes wrong would be the Backlight Inverter Board or the Power Supply Board. It's what powers the big screen like that. Replacement board for one of them would be well over $200. And we're not talking about labor on top of that from the repair shop.
If you get it, try to get warranty with it. Add on extended warranty if possible.
Jun 04, 2009 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
Sharp agous .. no power
I have same problem, In Caribean and repairs and new TVs are extra costly. Bringing power supply back with me to USA to see if I can buy a new one.
Aug 30, 2008 | Sharp Aqous LC-26D5U Television
Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Nov 06, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
35 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
