How does a person take off the top part of the washer to access the lid switch assembly? It is a Whirlpool LXR7244JQ0 washer?
  • 5,911 Answers
If you are talking about removing the outside washer casing, the following link explains the steps necessary to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you have not purchased a replacement switch, you can do so at searspartsdirect.com. Just type in the model number you provided and look for item number 9 (part number 3949247) under the "Top and Cabinet" heading. This is a very simple repair job if you follow the step-by-step instructions. If you require addditional assistance, please let me know. I hope this helps you.
PS For a cost comparison, you can also try replairclinic.com to see if they carry the switch for less. Use the part number provided.
Posted on Aug 28, 2008
How do I replace lid assembly for Whirlpool WTW8800YC 4.6 Cu. Ft. Cabrio Platinum Top Load Washer
Hi Sarah, there are two screws on each side of the lid holding the shaft for the hinges. Open the lid to access them, You will need an Allen wrench to take them off, after that, just lift the lid up to take it out. Hope this help. Thanks.
Feb 23, 2013 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hello, i have a kenmore top loading washer. it fills the maching but it doesnt want to wash, rinse or spin . please help . i have tried every cycle and still nothing. i would like to know what could be the...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 07, 2011 | Washing Machines
Fills but won't start. how do I access the lid
The following link explains how to access and replace a lid switch on a Whirlpool top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions, please post back and let me know. I hope this helps you.
Mar 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My kenmore washer 80 series model 110.23832100 won't spin. I think that is the switch lid. How can i replace it
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23832100
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Following is an illustrated guide for how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5f1af8349a77f9dc5632b02160e0d6c6
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
If the washer will drain but not spin the problem points to the Neutral Drain Assembly in the transmission.
The Whirlpool PDF has a very good explanation of how the assembly works.
Ours had the same problem, no draining or spinning unless the washer was stopped and restarted.
We replaced the neutral Drain Assembly for about $15 vs. $170 for a transmission.
If the Lid Switch is OK, please re-post a request for how to replace the neutral assembly.
Nov 19, 2009 | Kenmore 24032\24036 Top Load Washer
Replace lid switch assembly kaws850
The following link explains how to replace a lid switch:
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
Oct 30, 2009 | KitchenAid KAWS850L Top Load Washer
How to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Apr 20, 2009 | Whirlpool LSR6232J Top Load Washer
Lid switch replacement
none assembly may have metal shield under lever this was supposed to prevent breakage during spin cycles
Jul 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
