Question about Elna Quilter's Dream 6003Q
Burned out bulb.
How do I change the bulb?
  • 1 more comment
  • lexob Aug 28, 2008
    How do I get into small space to change bulb?
  • lexob Aug 29, 2008
    Maybe on some Elna's there's a hole on top,but not on the 6003Q.I removed plastic plug on the side....removed screw behind plug.. Wiggled loose plastic cover until it came off giving me access to bulb. lexob
  • lexob Aug 30, 2008
    Inappropriate was not the right rating. Sorry! Was upset that the instruction book that came with the machine does not have instructions on how to change the bulb. lexob
    Novelist:
  • 97 Answers
Generally on an Elna there's a little hole on the very top of the sewing machine directly above the bulb.
Pushing a long, skinny stick (like a screwdriver,) down into this hole will push the lightbulb and socket assembly down to where you can actually access the bulb without having to try to skvoosh your fingers into the tiny space.
-R
Posted on Aug 28, 2008
  • Rob Ristin Aug 29, 2008
    Inappropriate should be reserved for abusive or completely unacceptable/off topic solutions. Please change your rating, since my solution was, in fact, an honest attempt to help you with your problem; and perhaps may help another Elna user with a similar problem.
    -R
  • Rob Ristin Aug 30, 2008
    No problem. Thank you!
    -R
Bulb burned out on my Elnita 245i. Now I don't have power. Is there a connection?
go to this link and have a look around you might find out why ...
Oct 23, 2017 | Sewing Machines
What light bulb does the morse zig zag 4300 sewing machine take?
The Morse 4300 typically uses a standard 15 watt screw in style sewing bulb. Just like the one shown in the enclosed link. However, due to the age of this machine, it is possible that the light fixture has been changed at some point. If you have a burned out bulb, and it has a screw style base, this one will be right. There is also a push in style used on many aftermarket fixtures. Both styles of bulb are fairly universal though. So it will be one or the other.
Light Bulb 15 Watt Screw In 7SCW
Nov 02, 2015 | Sewing Machines
Bernina Display backlight not lighting but machine working
Bulb is burned out. Install a replacement bulb.
Feb 08, 2014 | Bernina Sewing Machines
Change bulb elna 6003q
removed plastic plug (with a small screw driver,so the plastic plug
does not get damaged) on the side of the face plate
carefully removed screw behind plug--be sure not to strip the screw head
carefully pull or wiggle loose plastic cover until it comes off
giving access to bulb.
Jun 03, 2012 | Elna Quilter's Dream 6003Q
I have a Viking 6440 (36 years old), and the original light bulb has burned out. I can't get the bulb out! Any suggestions?
Hi anon3...
Spray a little wd-40 on the socket and tap the outside of the socket...wait about a half an hour and try to unscrew it...if that does not work keep screwing the bulb out until you twist the bulb out of the socket...then take a pair of need nose pliers and grab the edge of the bulb and twist it toward the center do the a few times around the outside of the bulb
Please take time to rate me thumbs up
Sep 18, 2011 | Husqvarna Viking 1
I bought a new sewing machine light bulb to replace the one that burned out but can't get it ot screw in the socket. Are all sewing machines bulbs universal?
your bulb part number is X53061020 and no the blubs are not universal I would suggest taking the old bulb with you along with the part number I gave you in order to get the right bulb when you go to the store.
Sep 21, 2009 | Brother LS-1217 Mechanical Sewing Machine
Changing light bulb on viking designer 1
when one faulty, both do not work. replace faulty one & both will then work.
Jun 19, 2008 | Husqvarna Viking 1
Sewing Machines Logo
153 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
