I need the code for an echostar remote ir103602
I need the code for the echostar remote ir103602 to control a symphonic tv B-19wm manufactured in 1999
How to Program a EchoStar Remote Control
Instructions
Step1
Ensure that the remote control has new batteries installed. If you are not sure or have been using the device for a while, go ahead and insert fresh batteries. You need four AAA batteries.
Step2
Locate the mode buttons on the controller. You will see SAT, AUX, TV, and VCR. SAT stands for the satellite receiver. Your remote is automatically set up to work with your EchoStar receiver, and you do not need to program it for this function. AUX may refer to a cable television device or an audio device that hooks it into your stereo system. TV refers to your television set. VCR may be chosen to control a standard VCR or a DVD player.
Step3
Press the mode button that corresponds with the device which you want to control with the EchoStar remote control. For example, if you want to program the remote to control the TV, press down the TV mode button.
Step4
Turn on the device. This is the item you want to control with the EchoStar remote. You may need to do so manually or with its own remote control. In this example, you would turn on your television set with its own control.
Step5
Press down the EchoStar mode button for the device again, but this time hold it down for three seconds. You are going to notice that all the other mode buttons are going to flash on. Aim the remote at the device you want to control.
Step6
Depress the EchoStar remote power button briefly and then slowly click either the up or the down arrow button. You are performing a code scan that allows the remote control to run through all the preprogrammed codes that are stored in its memory. Proceed slowly and do not hurry this process. It may take a few minutes, but it is virtually foolproof.
Step7
Stop when the appliance you want to control with the EchoStar remote control suddenly turns off. You have hit upon the correct code, and if you save it now, your remote will be able to use it in the future to control the functions of the item.
Step8
Store the code in the EchoStar remote control’s memory by pressing the pound button. You will notice that the corresponding mode button is going to flash, acknowledging the programming choice. You are now ready to control the item with the EchoStar remote control.
Posted on Jan 09, 2009
I need the remote code in order to program my comcast cable remote
Posted on Aug 29, 2008
I HAVE A SYMPHONIC 19 IN B-19WM AND I DONT HAVE THE ORIG. REMOTE..I HAVE TRIED TO PROGRAM IT WITH RCA RCU704 SERIES UNIVERSIAL REMOTE AS WELL AS A ATLAS OCAP 5 DEVICE UNIVERSAL REMOTE AND NONE OF THE CODES...
Hello
You just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Symphonic is listed in its codes. Codes are: 0906 0520
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 17, 2011 | Symphonic ST419B 19" TV
Need code for remote control on a Symphonic TV/DVD mdl. # BL519DD Thank you
I can help you with your remote code problem for your Symphonic TV/DVD combo; I'm pretty good with remotes.
But first, I'll need the make and model number of the remote you would like to use with your TV: Remote codes are specific to the manufacturer of the remote (sometimes the model too) as well as to the brand of the TV.
I hope that helps.
Jul 08, 2010 | Televison & Video
Lines at the top of both my Symphonic tv's
You have a vertical deflection issue on both. Sounds like a bad capacitor. This repair is tricky but not expensive. Have a shop check it for you. Thanks for using fixya.
Feb 28, 2010 | Panasonic CT2722H TV
I have a disney princess T.V. and I lost the remote for it, I bought a univercial remote and cannot find the code to use it. I followed the directions and the code is not listed in the paper that came with...
My disney princess tv model P1310ATV uses code 759 with Echostar 6.2 and 6.3 remotes. This code is listed in the echostar manuals as a code for Hisense manufactured TV's.
Feb 28, 2009 | Disney 13" TV
Echostar 5.0 remote
https://rweb.echostar.com/departmental_content/TechPortal/content/tech/remotes/5.0.shtml
Dec 26, 2008 | Universal Remote Control Activity Based...
Tv won't recognize remote codes
If the manufacturer of the universal remote cannot give you codes for the Symphonic you are out of luck. U will either have to get an original replacement or get a Harmony universal remote.
Jun 25, 2017 | Universal Remote Control Remote Control
I need the codes for my Tv Symphonic I lost them
need codes for phillips-magnavox remote with a symphonic t.v
Mar 16, 2008 | GE RM24912 Universal Remote Control
Symphonic - 19 televison, B 19WM
This set doesn't have that option...accordianman
Dec 08, 2007 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Televison & Video Logo
1,970 people viewed this question
Top Televison & Video Experts
