Question about Intel Motherboard
Plugging in a USB port.
Trying to plug a USB port into the motherboard. It has 9 seperate wires and the motherboard is an intel desktop board D84SWN. I have no manuals and the port is in the front of the case. I found where it plugs into but I don't know the order of the pins.
  • 3 Answers
You have an A side and B side, or 1 and 2. Starting from pin 1, usually has an arrow pointing to it, the wires should read as follows: 1= A/1 +5vac 2= B/2 +5vac
3= A/1 -D 4= B/2 -D
5= A/1 +D 6= B/2 +D
7= A/1 ground 8= B/2 ground
9= no pin 10= no connection
Posted on Sep 09, 2008
How do i hook up usb button in intel 845 motherboard
Well, that's a start. You know you have an Intel motherboard in your eMachines, that uses an Intel 845 motherboard chipset.
It is an Intel D845GVSR motherboard.
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Left-click on the blue -
Intel Desktop Board D845GVSR Product Guide (PDF)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would advise upgrading to Adobe Reader X { 10 }, however, if you don't have it )
After you click on the above link, it may take up to 30 seconds before the first page comes up. (Took 6 seconds just now. Adobe Reader X, and medium speed DSL connection)
At the top of the PDF file, is the PDF file page number box.
It is to the left of the Down Arrow.
Go to Page 11.
T is the Front Panel USB header.
This is where the USB ports on the front of the computer, (Front Panel) connect to.
Go to Page 31.
E is the Front Panel USB header.
The Front Panel USB header is J9F2.
Observe the numbers next to the pins.
Go to Page 33.
This is the pinout for the Front Panel USB header, using those contact pin numbers.
1, 3, 5, 7, and 9 = one USB port
2, 4, 6, 8, and 10 = one USB port
Notice pins 9 and 10 are not used.
You can connect two USB ports to this header.
The pinout of ANY USB connector, female, or male, is set to a Standard.
This is the standard pinout for USB connectors,
http://pinouts.ru/Slots/USB_pinout.shtml
In case you cannot download the Intel D845GVSR motherboard manual;
Looking at the motherboard in it's normal position, installed into the computer case, the USB header is on the Bottom edge of the motherboard.
It is to the immediate Right, of the bottom white PCI slot (PCI 3)
It is to the Left of the motherboard mounting hole.
It is Below the Intel 82801DB, Southbridge chip.
Two rows of pins.
5 across the Top row, 4 across the Bottom row.
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Top are numbered,
Pins 2, 4, 6, 8, and 10
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Bottom are numbered,
Pins 1, 3, 5, and 7
Pins 1, 3, 5, and 7 = One USB connection
Pins 2, 4, 6, and 8 = One USB connection
Pin 9, and Pin 10 are Not used. (N/C. No Connection)
A) Pin 1 is for Power
B) Pin 3 is for D-
The Data, or Signal wire. It is the Negative connection
C) Pin 5 is for D+
The other Data, or Signal wire. It is the Positive connection
D) Pin 7 is for Ground
Going to the other USB header;
A) Pin 2 is for Power
B) Pin 4 is for D-
C) Pin 6 is for D+
D) Pin 8 is for Ground
For additional questions please post in a Comment.
Out of curiosity which eMachines is this?
Regards,
joecoolvette
Nov 24, 2011 | E-Machines eMachines Desktop PC
Hi sir; I have a pc with intel d845wn mother board.It is not supporting usb 2.0.What can i do
You may be able to upgrade the BIOS firmware so it can support USB 2.
You can download the motherboardBIOS upgrade and device drivers from Intel WEB site. Select your
model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers
thatmatches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Apr 29, 2011 | Intel Desktop Board D845WN Motherboard
How to connect audio & usb connection to mother board from front panel model no d 101 ggc help me
do you have the manual? there should be everything you need.
If you don't have the manual, here you go ;) Just follow the instructions and you'll be fine.
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
Mar 02, 2011 | Intel D101GGC Motherboard
Where do I plug the 2.0 USB on the board
you have a USB 2.0 enabled motherboard or USB 2.0 pci card? if you are plugging into motherboard and windows says that the device is not plugged into a USB 2.0 port, your motherboard does not support USB 2.0, and you need a USB 2.0 pci card. (try plugging into the rear USB 2.0 ports if you are plugging in the front) Hope this helps! Max
Feb 10, 2011 | Computers & Internet
I cannot get the 2 x 4500Gb SATA drives to show up in the BIOS of a intel s875wp1 board. It is an older board and had the RAID setup in place - I just want the 2 x SATA drives as normal so turned off the...
ATA/IDE has nothing to do with SATA. Ignore.
Try plugging in the drives into the non RAID sata ports on the motherboard. I think when you disable raid you also disable the raid ports. You should have another set of sata ports on the motherboard, probably a different colour.
Nov 26, 2009 | Intel S875WP1-E Server Board Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
WHERE TO INSTALL FRONT USB AND AUDIO CONNECTOR
This should help you. There are 2 USB headers located to the left hand side side of the board looking from the front and down. You should see 9 pins on each.. these provide 4 usb ports to front connector.
The audio connector is located towards the back, and sits just behind and between the PCI and PCI Express slots.
You can download the product guide here.
http://download.intel.com/support/motherboards/desktop/d101ggc/sb/d3458804_en1.pdf
and go to page 11/12 for the diagram.
Good luck
May 27, 2009 | Intel D101GGC Motherboard
Intel Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
