FixYa.com
Tags:
Sony Cyber-Shot DSC-S40 Digital Camera
Help! Sony Cybershot DSC-S40 won't load to XP Home
posted by Guest on Sep 08, 2005
I have a Dell GX-60 OS Win XP Home.
The driver that came on disk for the Sony Cybershot DSC-S40 is not for XP and sony said that XP should start the Wizzard and load the correct drivers from within XP.
Well it will not.
It says it can not find the driver.
I just get the yellow ? mark beside SONY in the devises listed.
Anyone have a suggestion?
Best Solution
posted on Sep 08, 2005
Thanks for Trying (70)
vega
vega - usenet poster
Rank:Wiz Wiz
Rating: 85%, 105 votes
This type of hookup works fine on my computers that have XP Home.
It sounds like the problem is with your computer.
Do you know for sure that the USB on your computer is working?
If you are not sure....You should check to see if Universal Serial Bus is listed in the Device Manager.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
vega
Rank:Wiz Wiz
Step One:
Reread the instructions on how to connect the camera to the computer, paying particular attention to what mode the camera should be in.
Step Two:
If the Sony instructions don't say what mode the camera shoud be in:
Make sure that the camera is turned on and in "Playback" mode (the mode where you can view the photos on the LCD), before connecting it to the computer.
Solution #3
Not Rated (0)
vega
Rank:Wiz Wiz
In the Device Manager, scroll down to the bottom and see if you find a device called "Universal Serial Bus controller".
And inside that device you should at least find "USB Root Hub".
If you do not have both of those devices, you need to contact Dell for instructions on how to load your motherboard USB drivers.
If that checks out, then find a friend with a computer with the XP operating system and connect your camera to that computer.
If it does not work on that computer, then it is time to return the camera and get a replacement.
Can you Help with these Digital Cameras problems?
Sony Cyber-Shot DCS-S40
My digicam says turn power off... Answer This...
Sony DSC-W100 PROBLEMS
I have a Sony DSC-W100 Digital... Answer This...
get an error message 19
As well as being unable to take... Answer This...
Sony DSC-S40 Cyber-shot
The LCD screen turns on but... Answer This...
Won't See the Memory Stick
My Camera can't see the memory... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
