Question about JVC Televison & Video
Player will not play DVD`s. It says reading disc on screen. Had an error message 162 on screen
  • 1 more comment
  • ronita4550 Aug 28, 2008
    The player is an FS-G5 consisting of CA-FSG% and SP-FSG5.. The discs are all loaded into player and the player will not eject them or play them.
    DVD Player FS-G5 will not play cd`s and also will not eject them. Just says reading disc
  • ronita4550 Aug 29, 2008
    I pulled all trays out with tweasers and found that one CD was stuck inside. I turned player upsidedown and shook it and was fortunate to have the CD dislodge and  was able to get it out of player. I reinserted CD`s into all other slots and CD player now works. I am not going to use the #3 slot as this is the one that was stuck. Thanks for the help.
    Master:
  • 521 Answers
Check the lens and clean if any dust is collected.
or try this.
I had the same error. I took it apart and it turned out (in my case) a couple of trays that had dislodged. Simply put it back in its rightful place (clicks in with a tiny bit of pressure). Now the system is playing fine.
or.
taking it to the repair shop will not not cost you much as they will reset the error by resetting machine they have and make it proper forever or for a longer period of time.it will not cost u too much. because they will not replace any part of the device.
but if the lens is gone totally bad then do not get it repaired because it do not last for long period.it will again show some different error.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 28, 2008
  • 6,487 Answers
Did you try a different DVD and see if it still have the same error, because if it play a different DVD so the problem is with the DISC..but if it still cannot play a different DVD the problem here can be the lens is dirty that needs to be clean , if you have a CD cleaner just run it to clean the lens...
Hope that helps...
  • Mark Gil
    Mark Gil Aug 28, 2008
    If that's the case there's a mechanism problem with the player and that's why it wont even eject the disc,, did you already turn the player off then see if it will eject the disc?? because if it wont still eject the disc you may need to open it and check the mechanism for the eject that may be bad already....
  • JVC Master
  • 13,433 Answers
Have you tried a dvd lens cleaner disk on this dvd player? I may need your model but I will check your error code.
  • 1 more comment
  • Ekse Aug 28, 2008
    I came across this when I was looking up the error code 162.
    Written by
    Steve Foster
    - 27th Oct 2007 16:17
    My 12 year old was having the same problem, Error Code 162, after 30-40 seconds of trying to read disc. Machine "locked up", hit the "shut off" button and took another 30-40 seconds to reset....usually with a click sound. I fixed it but not sure this method will work for everyone. First, I used another user's suggestion and pulled out all of the trays using a pair of tweezers. Found 2 CDs in their trays and removed both. Kept hearing a "shifting" or slight "clunking" sound when pulling out and/or pushing in the trays. At that point, pushing in tray #1 (bottom tray) became very very difficult. I didn't want to force it so I literally turned the machine upside down, hoping whatever was shifting inside the unit would fall back into place. Well....after several mintues of this, I pulled out tray # 5 only to discover ANOTHER disc that had not made it presence known before. Where was it during all if this?? Your guess is as good as mine. My daughter's reply: "Oh, that's where that other cd went to." Teenagers. I got all the trays to slide in/out very smoothly and tried another disc. No luck. Then I put a cd in tray #2, but pushed the button for tray #1, hoping that if it failed at reading #1, it would try #2. It did and it worked. I then tested playing discs and opening various trays at the same time just to make sure. Everything is working now. I'm going out today and purchase a lense cleaner, just in case. One final note: The "delay" from when I pressed the "stand by" button has also disappeared and now immediately goes into Stand By when the button is pushed Good luck.
  • Ekse Aug 28, 2008
    do post the model of your device,
  • Ekse Aug 28, 2008
    Thank you, we posted at the same time.
    let me know if this is any help or not.
    Thanks,
    Ekse
2 Suggested Answers
  • 25 Answers
SOURCE: DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Posted on Feb 18, 2010
We bought the Burlesque dvd and our blu-ray player cannot read the disc? The error messages 'cannot operate this disc and cannot play back this disc. This is the first dvd the blu-ray player cannot...
It's something about the Burlesque dvd. I have the same problem with mine when I try and play it on my Sony blue-ray player. It's the only disc I have that it won't play. Disc is a DVD Video disc but it will no't play in the Sony player. It plays fine on other dvd players and my computer, but not on the Sony.
Jul 16, 2011 | Sony Televison & Video
How do i get my th-a9r to play dvd-rw
You can't. The Laser will only Play +R & +RW.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Apr 23, 2011 | JVC TH-A9 System
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
My Panasonic TV has a built in DVD player. Won't read the disc- get message
Check and replace the laser pickup unit. It is faulty [Weak]. If you wish to get some details; visit the site linked here. Pull up older posts.
Dec 28, 2017 | Panasonic PV-DF2703 Triple Play 27 in....
DVV Player won't play disc
Check to make sure your player can play other disks. If so then use the disk doctor to remove the scratches on your favorite disk. The area that all DVD players scan before playing a disk is probably smudged or scratched.
Nov 21, 2008 | Philips DVP3345V/17 DVD Player/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Televison & Video Logo
213 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
