Question about Husqvarna Viking 1
Can't remember how to thread my #1 Viking 1200 sewing machine... thanks for the help. Eloise
  • 323 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 29, 2008
I can't find my manual and I can't remember how to thread the bobbin.
You can call them at 1-800-446-2333 and order a manual. If, you have a JoAnn's with a Husqvarna/Viking sewing gallery, I am sure that they will show you for free. They do have a website, at husqvarna.com also. Good luck
Sep 18, 2010 | Husqvarna Viking 1
I have received an old Husqvarna Viking from my grandmother which, she assures me is in working order, but she is unable to remember how to thread the machine and there are no instructions. The only...
This is going to be pretty veige, Im sorry but I have seen a lot of these go unanswered so hopefully this is at least helpful. All sewing machines have to do the same basic things, First the thread will go through a directional hole just getting it in the right spot, then it goes through the tension discs, then the take up spring, then the take up arm, then down through to the needle. I realize this this is veige, but I sure hope it helps.
Jun 01, 2010 | Husqvarna Viking 1
I need a viking #1 sewing machine manual
If you go to the dealer you can get another manual. Try going to the Viking site, you may be able to get a picture for the time being.
May 25, 2010 | Husqvarna Viking 1
I need a sewing guide, basic , starting with threading
Hi! You can find manuals for Husqvarna Viking sewing machines at http://sewingpartsonline.com/viking-sewing-machine-instruction-manuals.aspx. Another place to look for an instruction manual for your machine is http://www.sewconsult.com/husqvarna/husqvarna_instruction_manuals.htm. I didn't find anything about replacement instruction manuals on Husqvarna Viking's website--BUT they have a neat feature called The Sewing Room that offers how-to-sew instructions. (http://www.husqvarnaviking.com/us/3368.htm)
You can also take a look at my Hints and Tips about threading your machine.
Let me know if this helps!
Happy Sewing!
Feb 12, 2010 | Husqvarna Viking 1
How Need to know how to thread the machine and how
They have many different models so threading and winding the bobbin can vary due to your model. I would recommend calling them at: 1-800-474-6437 and see if they can get you a photo copy of your original owners manual.
Oct 15, 2009 | Husqvarna Viking 1
Can't get machine to pull up bobbin thread
This is a hook/needle timing issue. It will need to be adjusted by an authorized Husqvarna Viking dealer or they can send to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for them to do the repair. A list of authorized dealers is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Apr 17, 2009 | Husqvarna Viking 1
Sewing Machines Logo
175 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
