Toshiba RD-XS24SB I have this unit just over 2 years and the clock display has stopped. Despite numerous resets it fails to run but just maintains the last time entered on the screen.Would exhausted internal battery be the cause of this or how would you suggest I deal with this problem. It is a terrible nuisance as it renders the programmed recording function non existant. Mny yhanks in advance. regards, Arthur Ryan
  • 2 more comments
  • Anonymous Sep 15, 2008
    Exactly the same problem! Someone PLEASE ................ HELP!!!!!!!!!!
  • cilla7650 Nov 25, 2008
    RD-XS24SB - did you solve your problem? Toshiba say I need to call out an engineer.
  • sam3121 Feb 21, 2009
    I have exactly the same problem with a recently purchased Toshiba RD-XS24SB. Cannot get the clock to work. Am searching various forums, but just wondered if either of you have found a way to resolve this yet? It would be much appreciated.
    Sam
  • Anonymous Apr 16, 2009
    I have just switched mine on and have the same problems
    Will not auto update clock and when you set manual just stays the same
    I thought about looking for a internal battery ?
    Or just the clock update and run from mains frequency ?
    Brian566
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
My new Kenmore Electric Range, model 790.9419, purchased July 18, 2014...The clock no longer works. I press "clock", the code CLO appears; I set correct time; press START and the display goes blank an
That's an enegy saving "feature" - the ability to turn off the clock. Usually (in most models), you can turn the clock display back on by pressing and holding the clock 10 to 15 seconds.
Sep 17, 2014 | Kitchen Ranges
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
I have a Philips clock radio. Will the radio come on during a power outage with a battery?
Friend,
I agree that there is a battery in the device. But, it is only to maintain the time during power outage. It is just a button cell good enough to run the clock internally. It does not even show time, despite the clock running. And when the power restores, the time is displayed.
So, the answer to your query is NO.
Feb 01, 2011 | Philips AJL30837 Clock Radio
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
Power Supply Toshiba RD-XS24SB DVD Recorder
I have sent you correct page link, though manaul is availabale on charge basis $25.00 Give a close look at tha link ;)
Jul 31, 2008 | Televison & Video
IN 120 base keeps flashing CL
- press the OK key
Jul 09, 2008 | Lands Phones
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
256 people viewed this question
Top Televison & Video Experts
Electro Med Services...
