Question about Garden
Removing tractor deck to change belt and blades?
I have a 97-98 yardman lawn tractor model #13A1674G401, no manual, bought it used, need to replace broken belt and blades. How do I take the deck off?
  • Anonymous Mar 30, 2014
    19 horse 3 blade mower not getting any spark to the plugs
    Problem Solver:
  • 11 Answers
If i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
 http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
Posted on Sep 06, 2008
I changed belt on deck blades and now the blades will not turn.can u help
is the belt turning on the pullies but there not turning or is the belt not turning either
and you may not have the belt idler on right that is what is used to tighten the belt up
Jul 24, 2011 | Yard Man Yardman Riding Lawn Mower 38in...
Four year old yardman in need of belt replacement. (all belts) How do I go about this?
http://lawnandgarden.manualsonline.com check this site they may have a manual that could be of some use to you. Good Luck, also the belts themselves probably have model numbers on them that you can use as reference to purchase new ones from either Sears or perhaps a automotive parts store like Lordco
Mar 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Drive belt diagram for mtd yardman 42"
i need a diagram showing for a 20hp yardman tractor model number 13AT605G755
Dec 07, 2010 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Need to know what size and hoe to change belt for yardman 46" cutting deck for blade model # 13a0771h055
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
Jul 18, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
1,370 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
