Question about Pentax Optio S5i Digital Camera
View images on TV
I have Pentax OptioS5i. When i use the AV cable with the TV everything works OK, but the picture is black and white. I tried the camera with Samsung Biovision tv and a Sony tv also, the both are quite old (7-8 years old) and the both give me black and white picture. Could it be because of the tv or the problem is in the camera?
  • 21 Answers
Hi again: About the black and white pictures on the TV... not normal I think... I have never seen your camera model but a common thing can happen to any camera!! Have you already tryed to connect the camera to your TV using a AC Adapter (D-AC8 in your case)? Are the connections Ok? You're connecting following the manual instructions? If you don't have it download it... :) http://www.pentaximaging.com/files/manual/OptioS5i_Web.pdf Regards
Posted on May 16, 2006
SOURCE:
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
My wii when i turn it on it only has lines going across the screen.. about a week back it was saying something about the memory. now it wont load the wii menu nor will it load any games... if anyone knows...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Was this information helpful?
Nov 02, 2012 | Nintendo Wii Console
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
What to do:
  • AV Cables
  • Component Cables
Still Not Resolved:
Mar 06, 2012 | Nintendo Wii Console
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
Photos are black no image
CCD Failure !!
?Just call Pentax it is a known problem in thousands of cameras of different brands they will do it free of charge see the link below
Pls rate me FIXYA for help
http://www.imaging-resource.com/badccds.html
Pentax Support
http://www.pentaximaging.com/support/customer-care/
Apr 24, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Plug in the wii system and everything comes in black and white
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
Jan 18, 2009 | Nintendo Wii Console
Insignia TV - black and white
I would first try new cables, if not, then the board needs replacement.
Aug 16, 2008 | Insignia IS-LCDTV32 32 in. Television
Wii gone black and white, no colour
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Dec 11, 2007 | Nintendo Wii Console
Pentax Optio S5i Digital Camera Logo
113 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
