Question about Tablets & eReaders
Boot pxe e61 media test failure check cable my tablet started making some weird noise (I thought the fan may be going out), the system crashed and when I tried to turn it back on, I get the following message: IDE #0 ERROR Intel(R) Boot Agent FE v.4.1.10 Copyright (C) 1997-2003, Intel Corporation PXE-E61: Media test failiure, check cable PXE-M0F: Exiting Intel Boot Agent. Insert system disk in drive. Press any key when ready ... Trying to avoid the system disk, worried I might lose info since my last backup a couple of days ago.
  • 1 more comment
  • tecdax Nov 28, 2008
    I get Blue Screen og Dead after tri
  • Anonymous Feb 10, 2009
    the exact same message showed on my screen
  • Anonymous Feb 21, 2009
    i need to setup winxp on t3010d i do not have recovery disks
Sounds like hard disk faliure, suggest getting a new hard disk or perhaps attempt a system reinstall. Its not the fan but the hard disk.
Geoff
Posted on Sep 20, 2008
Toshiba portege 3500 tablet saya tidak bisa booting lewat external cd room .. yang ada di layar monitor terbaca : intel(R) boot agent version 4.1.06 copy right (C) 1997-2002, intel...
It means that the BIOS cannot find a disk to boot.
Make sure you selected the hard drive in the boot settings of your BIOS
Remove all external DVD drives or floppy drives or ethernet cables
If you get an error message, you should start troubleshooting your hard drive.
Feb 27, 2011 | Toshiba Portege 3500 Tablet PC
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Operating System Not Found
Hi and welcome to FixYa,
Almost always, your described problem indicates a hard disk problem: either it is no longer recognized (most likely) or the partition / files are corrupted.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Gateway M1200-3004265 Tablet PC
Operating system not found
That error message just indicates that the syswtem tried to do a network boot and couldn't since it did not detect an Ethernet cable connected to the port. Apparently your hard disk has died and needs to be replaced or your BIOS settings have changed and your hard disk is no longer in the boot order. Check your BIOS settings to confirm.
Jun 07, 2009 | Fujitsu LifeBook T3010D Tablet PC
Boot up problem
this is a easy fix all you need is a windows xp installation disk.what you do is put the disk in and boot off of the cd option.if you need help with the xp cd installation i can write up a guide for you.also is the first harddrive new or came with the comp.if it is a new harddrive it might not have a operating system on it.email me if you have anymore qeustions or you want the guide.i can even make a video for you but it probably won't be good quality.
Apr 23, 2009 | Toshiba Portege 3500 Tablet PC
Thinkpad x60 reboot fails. Error message: Media test failure
plz check the hard disk data cable(cable which is connected to motherboard), if changing the cable do not solve the problem your hard disk may be corrupt
Mar 01, 2009 | IBM ThinkPad X60 Tablet PC
Boot up problem
NOTE: Ususally when computers DO NOT find any startup information on the SELECTED DRIVE (like when you click a key) it goes to the default drive.
WHICH IS YOUR HARD DRIVE.
Meaning it is probably your Harddrive is broken, or your connection from hard drive to motherboard is broken
Burn a Live CD bootdisk of some linux distribution
liek Slax, google it.
Burn it to a bootable CD and put it into your drive, then select to boot from it.
If it boots only using your CD ROM drive, if that works then its probably not your BIOS/rest of computer, which is good.
And while in the live cd, you can see your harddrive and see files, that means its not broken its just your connection to it....either way im guessing youll have to send it in.
Jan 10, 2009 | Toshiba Portege R100 Tablet PC
Toshiba satellite 1115-S103 I can't boot up
It seems like your computer is booting from the network. This means that it is not detecting the Hard Drive. This error shows up when the hard drive is already busted or is not working anymore. You'll need to call toshiba for repairs or just get a brand new hard drive and install it yourself. It's pretty simple.
Aug 26, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Tablets & eReaders Logo
1,231 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
