Philips sunmobile hb871 sunbed lamps wont come on the controls have power coming through them then the time is set and you press the button for the sunbed to to start nothing happens but the timer starts to run
Sounds to me like either your capacitors have burnt out which you can see if you unscrew and lift the base cover of you will spot any burning excess or otherwise the board relay may not be switching which in this case the board needs to be replaced phillips are a nightmare to get hold of for these parts and you would have to order these in.. if you would like a second opinion if you are local within 20 miles bolton i will call in and have a quick look regards alex
01204 844111 www.supremesunbeds.co.uk
Posted on Feb 22, 2009
  • 639 Answers
Happy to assist you!
Perhaps a bad blower.
Sounds like an electronic failure you need a hands on diagnoses!
My words alone will not remedy the situation!
Do not wait to fix it next year to repair it!
The cost will be more then Bad Inflation!!!!!!!!!
You need to call service !!!!!!!!!!!!!
LET ME KNOW WHAT HAPPENS???
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 29, 2008
Ergoline sunbed, Sunbed lights keep going on and off while it's on cycle, it trips and the goes back on immediately does any one know what could be wrong?
Check your power supply rating of the circuit breaker that is feeding the outlet. The safety relay on the sunbed may be triggering because your circuit breaker won't allow enough current to flow to the sunbed. (The safety relay is far faster in actuating that the circuit breaker is to pop when drawing too much power.) Check the owner's manual and it will probably tell you you need a dedicated 16Amp circuit for the sunbed. These means the wiring has to be of proper diameter (gauge thickness) to handle the current. It shuts off and allows the sensor to cool down and then cuts on again... repeatedly. Also check the polarity of the outlet and ensure they match with the plug-in jack. (Often electrician's put the black wire and red wires on wrong poles inside the wall socket.. turn off the circuit breaker for the socket before changing them using an electrician's screwdriver with lamp inside the handle to assure the power is off first, please and make sure the green (ground) wire is connected also.)
Apr 24, 2015 | Health & Beauty
QuantumFx Rem-200 remote codes for philip TV no set up button
Hold down the tv button and then press and hold down the power key untill the light comes back on then press and release the power key untill tv comes on or goes off then press the (dvd) stop key and it is programed
Aug 25, 2012 | Universal Remote Control URC-200 LCD...
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
Hello., I've just tried to power up a Proxima 9310., and for the first time in my experience the orange light has come on and shut down has effected after a couple of seconds. I would like to ask for...
hi,
Time to replace the lamp of you projector.Lighting up of the orange light indicates that. All the projectors comes with self disorganizing program. if there is any complaint except power supply that will indicated by the projector by its self disorganizing system.
switch OFF the projector for some time. then power it ON. if picture come then first of all reset the lamp hour timer. To do the same do the follwing
1. Press the menu button and press rear click button or select button
2. Select settings press the rear click or select button
3. On setting display select Lamp age and press the rear click or select button
4. Move the arrow to Yes and press the rear click select button
OK will displayed and wait for your conformation
5. Move the arrow to Yes and press the rear click or select button
if there is no picture when you switch on the projector then go for a new lamp. you hve to do the reset procedure after replacing the lamp. It is always recommended the you should reset the lamp hour only after replacing the lamp.
ok
Apr 04, 2011 | InFocus Proxima Pro AV 9310 Multimedia...
How do i replace the bulb in an LG rear projection tv RE44SZ21RD
Note: Wear cotton gloves when handling the lamps as it contains mercury.
  1. Remove the access cover behind the On/Off switch at the bottom of the rear cover by removing the 2 screws using a Philip screwdriver.
  2. Behind the cover is a metal box with a handle that protects the rear of the lamp. Remove the securing screws and pull the box with the handle.
  3. Remove the cable screws and pull out the plug.
  4. Remove the lamp clamp screws and lift the lamp
  5. Put the new lamp in place of the old lamp in reverse sequence of the above.
  6. Dispose the old lamp properly.
  7. Reset the lamp timer.
  • Make sure the TV is on.
  • Press and hold Menu button on the TV set.
  • Press and hold Menu button on the remote control at the same time
  • Hold the buttons until the service Menu pops up.
  • Release the Menu button on the remote then on the TV set.
  • Press and hold Enter /Ok on the TV set then press and hold Mute button on the remote control.
  • Hold the buttons until the Lamp Life Hours screen pops up.
  • Release Mute button on remote then release Enter/Ok on the TV set.
  • Press Select twice to confirm the reset of the counter.
Oct 09, 2009 | LG Televison & Video
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Philips DVP3960 uncolck code
region-free hack?
I used the following and it worked fine for me on a recent purchase of a Philips DVP3960
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
Good luck
Feb 15, 2008 | Philips DVP3960
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Heating & Cooling Logo
922 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
