Question about Bose Lifestyle 30 System
No Sound I get power to the receiver but get no sound out of the system. I have checked all of the connections and still no sound, not even a hiss. Anybody with any ideas? Is there a fuse to protect the speakers? We had a big thunder/lightning storm last night, but the system wasn't turned on.
  • Anonymous Mar 08, 2009
    No sound from the system. Everthing appears to operate properly. Is there a reset or fuse in the sub-woffer? If so, hoe do you get inside the sub?
I cleaned the main speaker lead contacts, and IT WORKS.
Posted on Aug 30, 2008
My receiver only plays front speakers. when i put it in surround mode none of the speakers will play and the sub even in stereo mode is barely a whisper of sound. i dont have a remote for it but it goes...
you don't need a remote. to me sounds like you might have a connection problem. try and do a test tone which will send a test signal to all the speakers. starts from left to right etc. if you cant hear all the speakers you need to check all connection wires etc. hope this helps
Apr 08, 2014 | JVC RX-8000V Receiver
Pioneer vsx-454 not working propley.radio not even hissing,managed to get whisper sound via pc aux,i have cleaned inids?
It sounds like you're not in the right input source (mode) or you have a external source selected. I show your unit as a 1995 model and so check your Tape 1, Tape 2 selection buttons. These "Tape" selection button get dirty contacts that will kill the audio. To clean, with the volume low, press them on and off around 20 times each. This works the contacts back-n-forth and will help clean them.
Oct 31, 2012 | Pioneer VSX-454 Receiver
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Whwn I switch on the system and even when the sound is ZERO. there is a hissing/humming noise from all the speakers. Not sure whay this sound is there.
It is noise most often referred to as E.M.I. or R.F.I. ( electromagnetic or radio frequency interference). Sources of it can come from other devices plugged into the same circuitry or from nearby running appliances containing electric motors such as fans, or fluorescent lighting.
Things that you can do to reduce this are as follows;
Relocate the receiver and/or plug it into a different outlet.
Plug the receiver into an electronic interference rejecting device such as a power conditioner.
Use ferrite clamps on your power cord of the receiver and all of it's connected devices, and on the analog audio inputs.
Move any power cables closer than about 6" to any other cables connected to the receiver, and any cables crossing each other at 90 degrees.
Make sure all of your RCA, composite and coaxial connections are completely inserted on each end and tight.
Nov 14, 2010 | Audio Players & Recorders
Need help with SSI Cineplex 1500 Home Theater hook up..have all speakerwires hooked up,have 2 wire rca cable hooked up to input on system,going to output on satellite reciever, whaen I hit test tone I hear...
Hi, Hiss soundare from RCA cables.You need to reconnect again,but using a different cable for connection.
And also sometimes home theater acts that way during test mode, Check the manual and you will see how to set the home theater to see the mode that will allow all speakers to work. It's a normal thing when connecting a newly bought home theater.It the settings.Use the manual.
Take care.
Jul 07, 2010 | Audio Players & Recorders
Hissing sound
Do you mean audio hissing sound or is there smoke coming out the back?
Audio hiss with the FM tuner selected would mean it's between stations or you don't have an antenna. Try tuning around the band with an antenna.
Close what?
Connect what to what tuner? It has an internal tuner.
Apr 04, 2009 | Audio Players & Recorders
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
Very bad hiss even when power is turned off and battery is removed
If you use a sennheiser check your Squelch is not set to high / low. I use a Z1 and that solved my problem.
Feb 07, 2008 | Sennheiser EW100ENG-G2 2-Way Radio
Bose Lifestyle 30 System Logo
340 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
