Question about HTC Touch P3450 Smartphone
HTC Touch screen not responding!
Hi, yesterday my HTC Touch screen just stopped responding to my taps, I tried soft reset, hard reset, everything, you name it! I just can't get pass the alignment screen, because the phone wouldn't respond to my taps! Please help! I'm sure there are others out there who have the same problem
Thanks!
  • cayen Aug 29, 2008
    thank you, I will give it a try!
  • Anonymous Oct 16, 2008
    my htc tytn's touchscreen suddenly stopped responding to my taps...i tried all types of reset...soft and hard to no vail.... it hs stuck to the align screen ...pls tel what to do..
    Scholar:
  • 45 Answers
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
Posted on Aug 28, 2008
  • Stephen Aug 29, 2008
    I've also heard that removing and replacing the Screen Protector will sometimes fix the problem. They sometimes shrink to the point of putting pressure on the screen. If you have not added a screen protector, then please disregard this step.
  • ntnc Nov 13, 2010
    Running the business card fixed my problem since some dirt was lodged.
    (Though my phone model is HTC touch 3G).
    Thanks for the suggestion! It was very useful.
  • 3 Answers
Screen protector was causing the problem for me. Resolved now, after trying out sol#3 suggested by SuperSport66
Thanks,
Karthik
Posted on Nov 27, 2008
Sloution: hey friends my htc p3400i was fell a little on bed after that its touch screen used to work ocassionally, i went to repair shop he told its touch sensor has to be replaced in 600/-, i was damm sure my touch sensor might not be damaged so i puchased screw driver set and opened my mobile, there is one site u can find on google which has service manual of all PDA's. As i was thinking the problem was same the connection was loose i tightened it by cello tape as the scew was broken(i think earlier when my screen was cracked the rapirer chaged many things in my ciuitery as it was not looking fresh one, though it was a new phone), and now its working fine....i m too happy.
Posted on Oct 21, 2009
Moist from sweat was my problem, I resolved this with a hairdryer.
be patient while doing this, it takes some time.
Peter
Posted on Dec 09, 2009
I am having htc p3450 touch mobile, last day i bought a new mobile pouch for it, it was tight one then i kept my mobile in that tight case for one night, the next day the touch screen dint work please send me the solution
Posted on Mar 31, 2011
The business card solution worked for me...thx supersport66
Posted on May 01, 2010
How to restore HTC One V T320e smartphone
Performing a factory reset using hardware buttons
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
Performing a factory reset from settings
1. Slide the Notifications panel open, and then tap Settings.
2. Tap Storage > Factory data reset.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
Sep 26, 2013 | HTC One V T320e - 4gb - Grey Unlocked...
My HTC P3000 switches on but touch screen does not respond and its screen is locked and stylus tap does not work
pratik63331... havin a touch screen prob... well it iz a bit tricky... try the alingment option and thn try...!!! if still dosnt wrk try hard reset..!!
Apr 06, 2009 | HTC Computers & Internet
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Feb 12, 2009 | HTC Touch P3450 Smartphone
Touch screen not responding at all
The touch pad is dead...it's a hardware issue...go to the vendor or workshop...within a year it is replaced for free.Good luck.
Feb 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Htc touch screen not working.
Hi, I had the same problem. Whenever, I touched my screen the wrong things would respond, then finally one day my phone locked & when I tried to unlock it the screen wouldn't respond at all.Took my phone to 3 sprint stores and all the techs couldn't help. One even accused water damage or overheating because they saw spots under my screen. But I never wet my phone so I thought it might be overheating since I do live in a warm climate. They all tried to get me to buy a new phone, which seemed like a scam. I didn't want to hard reset & lose all my data so I looked closer at the screen & noticed the spots didn't look like water spots & peeled the screen back. I noticed that the glue from around the screen actually leaked onto the screen, so I dampened one end of a q-tip & wiped the glue off the dryed it with the other end. I turn the phone back on and the screen worked fine. Try cleaning thr screen before doing a hard reset or paying for a replacement phone. It'll save you time & headache.
Hope this helps =)
Jan 09, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Htc touch p3450 is not responding to stylus taps or finger taps
you needto replace the ants which live behind the touch screen
get some fresh once from your garden (or park) if you don't have a garden
Open phone( oh not allowed or warrenty void)
WHAT warrenty?
anywat open phone and you will see a few dead ants behind the screen.
Replace ants with fresh live ones
Close phone (quickly or ants excape)
power on phone
Never do hard reset on phone
It will electrocute some ants
Jan 07, 2009 | HTC Touch P3450 Smartphone
HTC Touch - Screen & touch flo problem
i did all things described to get the screen workin,pressed the red n green buttons simultaneously n with the friggin stylus i pressed the reset button underneath, pulled the battery out a coupla million timesn put it in, but it jus doesnt unlock, the touchscreen aint workin, i can call, mssag or do anything except recieve calls, Arpan
Nov 12, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
My tytn ii touch screen is not responding
I have had the same problem but have finally got past the alignment screen by putting a new text document called welcome.not onto the memory card. At least the phone is working now, but the screen is not. HTC have sent me the phone back wanting £360 because they say it is water damaged even though it is less than 12 months old.
Nov 08, 2008 | HTC TyTN Smartphone
Touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Jun 25, 2008 | HTC P3300 Smartphone
HTC Touch P3450 Smartphone Logo
13,358 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
