Can't log in windows vista
I have problem with login in my Dell laptop with windows Vista. The problem is when i log in , then walk way, it'll lock up by itself. That's normal. The problem is when i enter my user ID and password, then hit enter or click the arrow to log in, it won't do anything. I had to hold the power button to shut it down then log back in then it worked. Please help, thank you very much, any help would be very appreciated. Thanks.
  • 1 more comment
  • hnguyen Aug 29, 2008
    Thanks Pyrhyc. I'll try that. I'll let you know the result. Thanks again for you help.
  • bleach808 Sep 10, 2008
    I can't get into windows vista. when i power on the laptop it goes to screen that says test, i click on test it says logging off but then goes right back to the same screen. The only thing it will let me do is to log off or shutdown. i tried going through dos mode but that didnt work either. i just recently had the motherboard replaced by hp under warranty but i had to pay 50 bucks to talk to a technician. now they want to charge me another 50 bucks to talk to a tech about this problem. i have only had my laptop back for 1 week.
  • hnguyen Feb 16, 2009
    i agree, the windows repair definitely will fix the problem. but i fixed my problem by do the " sfc \scannow" in the Run command. you'll need the windows Vista CD in the cd-rom though. this command will restore all the system files back to it original state. All the files and application won't be affected by this . So it's safe to run this first before doing the windows repair.
    Genius:
  • 2,028 Answers
Go into the power settings and disable the password prompt when resuming from standby. If you want it to prompt for the password then restart the machine and enable it. This should clear up the glitch. If it doesn't, then you can try either a system restore or a system repair with your recovery or operating system disc. If the restore doesn't fix it, the repair definitely will.
Posted on Aug 28, 2008
Hi i can log on to my computer it ask for a pasword but when i type it in all it say is the user profile has failed and cant be loaded
Posted on Sep 15, 2009
2 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: there is no room to enter a domain.
I'm assuming that the operating system is XP.
Log in to your account as you usually would. Right click on My Computer and select Properties from the list. Click on the Computer Name tab. Where it says "To rename this computer or join a domain" click on change. A new window will pop up so click on Workgroup. In the typing plane if it say's MSHOME, delete that and type WORKGROUP make sure you type it in uppercase (capital letters).
When you've done that click OK.
The computer will tell you that you have to restart the computer for the changes to take effect so please restart the computer.
Once the computer has restarted you can check if the domain has changed to WORKGROUP.
Please post back if you need anymore help.
Regards.
Posted on Oct 02, 2009
How to do if locked out of Windows 8 laptop?
1. Run "lusrmgr.msc" to reset Dell Windows password.
In Windows 8/7/Vista/XP, there is an easy way to reset a forgotten user account password by just run the lusrmgr.msc. But you need to login your server or laptop with an account which has admin privileges. Note that resetting password with this tip might cause irreversible loss of information for the user account. This data loss will occur the next time the user logs off. You should use this command only if a user has forgotten his or her password and does not have a password reset disk.
Step 1. Start your PC and log on with an available user account which has admin privileges.
Step 2. Click "start" button, press "Win+R" to open "Run box". Type in "lusrmgr.msc" and hit Enter.
Step 3. Local Users and Computers appears, all user accounts of your computer will be list, right-click your user name and select "reset password".
Step 4. Type in a new password and type it again to confirm it, click OK.
After restarting you can login that user account with new password.
2. Remove Dell password by using a Windows password recovery tool.
This is a universal way to reset forgotten Windows password on HP Server or PC, no matter what your Windows system is, Windows 8/7/vista/XP. iSunshare Windows Password Genius is designed to recover Windows password for any kinds of PC, such as hp, dell, acer, Toshiba, Lenovo, IBM etc. It not only can help reset server or laptop password Windows 8, but also Windows 7, Vista, XP and Windows 2000.
Step 1: Download and install Windows Password Genius Advanced on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk with CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your PC or Server and set the laptop to boot from the disk by changing devices boot order in BIOS SETUP.
Step 4: After boot from the password recovery disk, Windows password recovery tool will start automatically and display a friendly window. Then you can reset whichever account password of your PC or Server by a few clicks.
Windows Password Genius also allows user to create new admin account for your Dell Windows system without logging. With this new user, you can login your Dell computer directly and access control panel to reset other user password.
Jul 29, 2013 | Computers & Internet
How to unlock my dell laptop
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
Jul 26, 2012 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
How to reset lost password?
What OS are you having?
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Reset
Hope you can reset windows password soon.
Jul 09, 2012 | Dell Inspiron 8600 Notebook
How do i reset my laptop to factory settings
Reset windows password as following instruction :
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Reset .
Jun 23, 2012 | Computers & Internet
I forgot my windows login password for a dell studio 1737 laptop
Now you can reset windows password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Recovery Tool 3.0 .
Jun 22, 2012 | Dell Studio 1737 Laptop
Latitude D430 PC Notebook: i forgot my login password and i cant get into my ...
You have to reset the PC and while booting press F8 until the OS menu shows up, choose start safe mode. When you reach the Login part you will be able to login as an administrator, while you are logged in as Admin change your user password.
Word of advice, change to Windows XP or Windows 7 because Vista is the worst OS I saw. Cheers
May 18, 2010 | Dell Latitude D430 Notebook
I could not do Map Network Drive from other pc to my Dell Inspiron 1501. It looks like security setting is violated. I got message saying 'c' is available but the user account that you are logged on with...
If you are using Window's XP or later the problem is probably the account you are logged into doesn't have "administrative access". You will have to log into the administrative account to make network changes.
If you are running Vista the default administrative account is hidden. To access it do the following: First you’ll need to open a command prompt in administrator mode by right-clicking and choosing “Run as administrator” (or use the Ctrl+Shift+Enter shortcut from the search box)
Now type the following command :
net user administrator /active:yes
You should see a message that the command completed successfully. Log out, and you’ll now see the Administrator account as a choice. (Note that the screenshots are from Vista, but this works on Windows 7)
You’ll note that there’s no password for this account, so if you want to leave it enabled you should change the password.
Disable Built-in Administrator Account
Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:
net user administrator /active:no
The administrator account will now be disabled, and shouldn’t show up on the login screen anymore.
Feb 05, 2010 | Computers & Internet
Forgot asus laptop password Windows vista
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Feb 19, 2009 | ASUS Eee 4G Notebook
WIndows xp on dell
hello
you have to delete vista for intalling xp,after xp you can can install vista,format vista first with linux
Nov 07, 2008 | Microsoft Windows XP Professional for PC
Desktop is blank white
The problem can be solved by reinstalling windows vista.
Oct 24, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
3,429 people viewed this question
David Payne
David Payne
